Upgrading a Thor Design's 637
Re: Upgrading a Thor Design's 637
Postby Tommydeen » Sat Aug 20, 2011 2:07 am
no worries Tim..I know all about duty.. its all good :wink:
Tommydeen
Postby SubICman » Sat Aug 20, 2011 9:35 am
Tom,
Here you go, I took a crap ton of pictures of the towed array tube and fairing. Hope it helps, Getting ready for our Subron 4 meeting today.
One word about the towed array fairing casting. The alumilte continued to cure and shrink, at the beginning of this year, I had to re-attach the fairing and pin it into place, hence some of the primer spots on the casting. My plan is to repaint topside this winter
When surfaced, the bridge access hatch can be optionally open or shut, however, when submerged it is required to be shut. (Really a no s***t precaution from a procedure in use in the sub fleet today.)
SC #3116
SubICman
Postby SubICman » Sat Aug 20, 2011 10:06 am
Opps,
Forgot the ones with the ruler in the pic. I only have a steel one so thery are not the best.
SC #3116
SubICman
Postby SubICman » Sat Aug 20, 2011 10:22 am
Continueing with the mast construction. I cut pieces out and placed them up against the scale drawings to get the lengths and curves set right. I took a piece of brass tubing (can't seem to find the size I used in my notes) and squashed it into an oval with a vise to form the antenna portion. I also pulled my scope barrel out of the resin mast. For the BLA-4 i turned to my trusty acient Craftsman metal lathe and turned a new antenna for that. I soldered everything together very carefully, when working with stuff this small, a micro torch is a MUST!
SC #3116
SubICman
Postby Thor » Sat Aug 20, 2011 3:45 pm
Tim,
Yes! When you get those drawings done send them over and I will get to work doing what I can. I should have everything set up in the new shop by late spring and my health should be back to the point that I can operate the machinery. I really miss that old Sturgeon of mine. I wish I could remember who I sold my old boat to. I would buy it back. It was the one I had at the 1994 & 1995 Regatta. What a stupid move to sell that boat!!!
Thor
Postby Tommydeen » Sun Aug 21, 2011 3:46 am
Wow thanks alot Tim the pics help!!!!!
Tommydeen
Postby Rogue Sub » Thu Aug 25, 2011 10:50 pm
Tim- BUTCHER!!
Thor- I thought I was your favorite Nuke?
Kevin
A Global Force For Good
http://WWW.ROGUESUBWORKS.COM
Rogue Sub
Postby Thor » Fri Aug 26, 2011 4:40 pm
:roll:
oh, boy......
Thor
Postby wlambing » Fri Aug 26, 2011 4:55 pm
Kevin,
You are, dork! Tim is a non-nuke twigget!!!!! Formerly a two-wire electrician. Sheeeshh!! How quickly they forget!!
B^)
MMCS(SS) USN (Ret.)
World's greatest living Submarine Auxiliaryman
and friend to small furry creatures
wlambing
Postby Rogue Sub » Fri Aug 26, 2011 8:29 pm
Bill are you a member of the furies?
Kevin
Rogue Sub
Postby Rogue Sub » Fri Aug 26, 2011 8:37 pm
Just so there are no misunderstandings....
Kevin
Rogue Sub
Postby wlambing » Sat Aug 27, 2011 9:39 am
Kevin,
No. They're not small, nor furry enough!
B^)
wlambing
Postby Rogue Sub » Sat Aug 27, 2011 10:05 am
I am not convinced
Kevin
Rogue Sub
Postby JWLaRue » Sat Aug 27, 2011 2:12 pm
....nor pink enough? :)
JWLaRue
Postby SubICman » Wed Aug 31, 2011 7:43 pm
jeez, go out to sea for a week and you guys hijack my thread for FURRIES?!?!?!?!
SC #3116
SubICman
PreviousNext
Return to Builder Threads
