what not to do with polyester
Postby raalst » Fri Jan 05, 2007 5:38 pm
I did my first lay-up a few days ago.
The idea is to create a strong shell to protect the foam/gypsum plug
(and as a basis to apply further filler).
As there were concave surfaces and
sharp edges I wanted to fix my glass weave to the hull first,
then apply polyester.
I used white wood glue for this. Turns out that the glass/polyester
mix now detaches from the hull in exactly the spots where glue was used.
that's not what you want....
Postby U812 » Fri Jan 05, 2007 6:32 pm
I just use 3M 77 lightly over the foam and smooth down my glass just perfect, then I apply the resin.
BTW polyester you need to let sit a few days before snading or you'll clog your sand paper. Wet sanding helps with this is the resin is quite there yet.
That's why I stopped using polyester. Besides the smell it always took longer for the surface to cure or I was doing somethime wrong. But with epoxy 24 hours and she ready to sand.
The 3M 77 works real good and I've done many many hulls and RC jet plugs this way.
steve
U812
Postby raalst » Fri Jan 05, 2007 6:58 pm
thanks steve,
unfortunately I have never seen it over here in the neterlands.
but i'll have a search for it...
Postby tsenecal » Fri Jan 05, 2007 8:26 pm
thinking outside the box:
I use 3M 77 as a tack glue to mount photos on mattes.
try looking for a low tack spray adhesive in photo and camera shops or frame stores if you can't find the 3M 77.
tsenecal
Postby raalst » Sat Jan 06, 2007 6:03 am
thanks Tsenecal ! that is a good lead.
I must admit I have seen it once, used by a consultant in a workshop.
so office supply stores are another place to search.
Postby Sub culture » Sat Jan 06, 2007 8:34 am
I haven't used the 3M product, however I think it may be a contact type of adhesive?
Upholsterers use a spray contact adhesive to fix cloth onto foam cushions etc.
You could try a local upholstery shop and ask if they have a can they could sell you.
Postby raalst » Sat Jan 06, 2007 10:10 am
found it.
the local bookstore had it tucked away somewhere...
thanks for the leads.
A bit off topic
Postby Mkeatingss » Sat Jan 06, 2007 4:24 pm
I'm sitting here reading this, and a picture keeps popping into my head.
It's of the salesman's face, when you walk into an office supply or upholstery shop, and say, "I'm building a working model submarine, and I need some help." Or words to that effect.
Probably similar to the look I got, the first time I walked into my local model Railway shop and stated, "I'm building a model sub and need some diesel engines."
Or the poor woman. at the sewing shop. when I asked for the thinnest single strand thread she had. She asked what I needed it for. I just said, "My submarine." I wish I'd thought to bring a camera.
Mike K.
Mkeatingss
Postby aeroengineer1 » Sat Jan 06, 2007 10:13 pm
Mike I have had that experience many times even going to the local hobby shop asking for things. I tell them that it is for a model submarine and the get the stupid dog look on their face and then state that they do not sell parts for a model submarine, that all thier stuff is for cars or airplanes. I love it wen I tell them that it is ok, it works in a submarine too.
Adam
aeroengineer1
Postby Crazy Ivan » Sat Jan 06, 2007 11:41 pm
I've even had it happen trying to buy loose o-rings at the home center. "No, it's not any kind of faucet, it's for my submarine." Sheesh, you would think at least a hardware oriented store would understand such things. No way. I'll have to see how it works at the local marine supply store.
Crazy Ivan
Postby Bigdave » Sun Jan 07, 2007 10:06 am
George, I went to the Doctor the other day and had an 8-ball shirt on. He looked at the logo and thought it was a BOMB!! Ha!! BD.
Postby Sub culture » Sun Jan 07, 2007 3:45 pm
Silly sod, how could he make a mistake like that!
:lol: :lol:
Postby raalst » Sun Jan 07, 2007 6:30 pm
just for completeness,
it seems the wood glue was not the mayor cause for the problem.
I pried open a blister and it turned out that the whole glassed area
was still soft. not just where the glue was, but everywhere.
It also detached easily from the gypsum.
I peeled the majority of it off the plug.
so I conclude there must have been a problem with the hardening
process. too little hardener or maybe too low a temperature, who knows.
The other side of the boat went much better and is now
covered in a hard shell.
back to work.
Postby Crazy Ivan » Sun Jan 07, 2007 9:47 pm
Possably a moisture problem when you glassed the first side. Curing resin does not react well to moisture underneath it.
Crazy Ivan
