Flood Valve
Flood Valve
Postby Bigdave » Thu Feb 23, 2012 6:19 pm
I have had a few requests for info on how I made my flood valve for my sinking tanker.
So I am posting some basic info on how it is made.
The sizes can vary depending how fast you want the hull to flood so I am showing no exact sizes.
The body or frame of the assembly are made from K&S brass strips and bent in a U shape.
The bottom part being the largest which also has the opening in the bottom for the water inlet.
The top frame is also U shape but has shorter sides. This is attached to the bottom frame by a screw on each side.
The the valve body was turned on a lathe to match the size of the O-ring used.
The shaft the body is mounted to is K&S brass rod soldered on.
The guide tube was soldered to the upper frame. This just gives the shaft support and keeps it centered above the intake hole.
The spring keeps the O-ring pressed between the valve body and intake hole.
The valve is activated by the arm which acts like a lever when pulled back thus pushing up on the collar attached to the shaft.
This lifts the O-ring and lets the water in. Very simple! :D
There will be a test in the morning! :roll: So do your homework!! :mrgreen: BD.
Re: Flood Valve
Postby salmon » Thu Feb 23, 2012 7:25 pm
Really sweet design. Thank you for sharing!
tom
Re: Flood Valve
Postby Jure George » Thu Feb 23, 2012 10:44 pm
Hey Dave
I would also like to thank you for the information!
George
Geroge Tonkovic
Jure George
Re: Flood Valve
Postby JWLaRue » Thu Feb 23, 2012 11:24 pm
BD,
....so once you sink it, how do you bring it back to the surface? Throw Don in after it? :mrgreen:
Re: Flood Valve
Postby Bigdave » Fri Feb 24, 2012 9:18 am
That only works the first time. :roll:
He is smart enough not to fall for that trick again. :lol:
I have a small RCABS system in the hull which is just enough to bring the boat back up.
You can actually run the boat at decks-a-wash so I drive it over to the side of the pool and then empty out the water manualy.
I did not want to over complicate the system by adding a second pump to empty the hull.
As Skip always says. K.I.S.S! :mrgreen: BD.
Re: Flood Valve
Postby Pirate » Sat Feb 25, 2012 11:16 pm
Dave, have you posted pics of this tanker somewhere?
Re: Flood Valve
Postby JWLaRue » Sat Feb 25, 2012 11:35 pm
Pete,
Some video of the tanker "in action" here:
http://s181686668.onlinehome.us/phpBB3/viewtopic.php?f=31&t=10747
Re: Flood Valve
Postby Bigdave » Sun Feb 26, 2012 8:47 am
Pirate wrote:Dave, have you posted pics of this tanker somewhere?
There is a post in my Dockyard section called the Sinker that has info on the Tanker. Dave.
