Balsa wood and fiberglass
Postby Jeffrey J » Thu Apr 21, 2011 8:30 am
hey guys,
When adding fiberglass to a balsa model can you just apply the fiberglass and polyester resin directly to the wood ? Also, how many layers of cloth and resin do you need over balsa wood before you start getting enough strength built up to call it strong enough for your model?? thanks in advance Jeff Jones
Jeffrey J
Re: Balsa wood and fiberglass
Postby fgroza » Thu Apr 21, 2011 9:20 am
Depending what you are doing, say glassing a hull on a surface ship, I use light weight cloth .5oz to 4oz,and epoxy-- finishing resin-- rather than polyester resin. I like the sanding quality of the epoxy over the polyester and the smell is less noticable. You can build up layers of cloth/resin if need be, and heavier cloth could be used, depending on the application.
Great Planes, Zapp, and others make a slow setting finishing resin/epoxy for doing this type of work. Another supplier is West Systems- full size boat supplier-- that you can choose what type of hardner and epoxy you need.
When applying the glass ,I usually coat the wood and squeege resin through the the cloth after placing it on the model. I try to remove as much of the eccess resin as I can at first, then recoat after the first coat cures, sanding between coats.
Hope this helps
Frank
fgroza
