For Sale: U-Joints, Speed Controls and Miscellaneo
Postby TKasinec » Wed Jul 07, 2004 2:42 pm
For Sale: U-Joints, Speed Controls and Miscellaneous Items.
Free shipping within the 48 states is included for each item.
U-Joints:
. 1 New, made of Delrin w/brass inserts and spider, heavy duty. 3/16" shaft to 3/16" shaft, 1 ¾" Long by ½" Dia. $17.00.
. 2 New, made of Delrin w/brass inserts and spider, standard duty. 1/8" shaft to 1/8" shaft, 1 1/2" Long by 3/8" Dia. $13.00 each.
. 2 New, made of Delrin w/brass inserts and spider, standard duty. 3/16" shaft to 3/16" shaft, 1 1/2" Long by 3/8" Dia. $13.00 each.
Speed Controls:
. 3 New Hi-Tech Electronic Speed Controls, # SP-610-RF, in original boxes and includes paper work. Voltage range is 6 to 8.4 volts at a maximum 10 amp load.
$30.00 each.
. 1 Brand new SONIK ECO-20 speed control. Very small, 1 3/8" x 1 3/8" x 5/8" thick. Completely waterproof, will handle hot motors down to 20 turns with peak amp draw of 210 amps and 75 amps continuous. Input voltage of 4.8 to 9.6 volts (4-8 cells). Has BEC output circuit of 5 volts to power the radio receiver and servos. $40.00.
Miscellaneous:
. 1 New Clippard Valve, #EV-2-12VDC. $25.00.
. The STUPH AT5 by Aqua-Tec. Water protection for electronics. Brand new 6 fl. oz. bottle, in original packaging, untouched. I don’t think this stuff is available anymore? It waterproofs electronic components. Dip or spray your receiver and servo boards and connectors with this stuff and if they get wet, they keep on working. Also prevents moisture and rust corrosion. 6 fl. oz. bottle (probably a life-time supply). $20.00.
Please e-mail me, or call, with any questions you may have at:
jkasinec@juno.com or (269) 323-3102 (Michigan)
Best Regards,
Tom Kasinec, SCM #1009
TKasinec
Return to SubSwap
