For Sale:  Motors and Belt Gear Drive Units.
Postby TKasinec » Wed Jul 07, 2004 2:40 pm
Free shipping within the 48 states is included for each item.
Dumas/Pittman Motors:
. 2 new matching Dumas Motors, #2005, 12 volt, in original boxes with dog bone connectors, motor mounts and paper work included. $50.00 for each motor.
. 1 like new Dumas Motor, #2005, 12 volt, in box with dog bone connectors and motor mount. $40.00.
. 1 like new Dumas Motor, #9004, 6 volt, "older style shape" in original box with dog bone connectors, motor mount and paper work included. $40.00.
. 2 like new Pittman Motors, dated 1985, 12volt. $30.00 for each motor.
. 2 new, never used, matching Pittman motors, dated 1988, 6 volt, with new Sub-Tech 3:1 ratio gear reduction units installed on each motor. Both motors are set in one aluminum custom built motor mount for two propeller operation. The motor mount is designed to accommodate propeller shaft spacing of 3" from center to center. Overall width is 7", can be changed to a width of 5". $175.00 for the complete unit.
Maxon Motors:
. Used Maxon motor with 6mm or 1/8" shaft. These motors will turn the prop 2800+ RPM, on direct drive, with only .1 Amp draw on 12 volts. Maxon motors are made out of stainless steel with no venting holes. They look like they have been turned out of a solid block of stainless steel. These motors are made in Switzerland and are of very high quality and precision. They retail new for around $200.+ dollars. Used motor price: $75.00.
Belt Gear Drives:
. 2 new Sub-Tech Gear Drive Units. Each unit has two 1/8" bore pinion gears. One being a 12 tooth pinion gear for a 2.5:1 ratio and a second 10 tooth pinion gear for a 3:1 ratio. $50.00 for each unit.
Please e-mail me, or call, with any questions you may have at:
jkasinec@juno.com or (269) 323-3102 (Michigan)
Best Regards,
Tom Kasinec, SCM #1009
TKasinec
Return to SubSwap
