Propellers For Sale
Postby TKasinec » Fri Jan 23, 2004 5:05 pm
Free shipping within the 48 states is included for each item.
Item #1: One 5 blade "Albacore" Brass prop made for SubTech’s Albacore. RH pitch, approx. 2 ¼" dia., 3/16" smooth bore with set screw, for 3/16" prop. shaft. The Albacore dog bone and 2 Dumas couplings are included with prop. I think this prop. design is only for the "Albacore", it has a very large Boss. $45.00 for the prop. and drive components.
Below are sets of propellers I have available:
Set #1: 3 blade Brass, made by The Prop Shop. RH and LH pitch, 42mm dia. (approx. 1 5/8"), 4mm threaded bore. These props. would work well on a 1/48 scale Type XXI or similar size boat. $60.00 for the pair.
Set #2: 3 blade Brass, made by The Prop Shop. RH and LH pitch, 35mm dia. (approx. 1 3/8"), 6-32 threaded bore for 1/8" prop. shafts. These props. would work well on a 1/32 scale Type II or similar size boat. $50.00 for the pair.
Set #3: 4 blade Brass, made by The Prop Shop. RH and LH pitch, 55mm dia. (approx. 2 ¼"), 10-32 threaded bore for 3/16" prop. shafts. These props. would work well on a 1/48 scale Gato/Balao or similar size boat. $100.00 for the pair.
Set #4: 4 blade Brass, made by E. Radestock. RH and LH pitch, 32mm dia. (approx. 1 1/4"), 4mm threaded bore. These props. would work well on a 1/72 scale Gato/Balao or similar size boat. $40.00 for the pair.
Set #5: 3 blade Brass, made by 32nd Parallel. RH and LH pitch, 40mm dia. (approx. 1 5/8"), 10-32 threaded bore for 3/16" prop. shafts. This is an original set of 32nd Parallel props. made for their 1/32 scale Type VII. $40.00 for the pair.
Set #6: 7 blade Scimitar, Brass, made by The Prop Shop. RH and LH pitch, 55mm dia. (approx. 2 ¼"), 3/16" smooth bore with set screw, for 3/16" prop. shafts. These props. have a 5/8" Boss with a nice long Dunce Cap and would work well on a 1/96 Typhoon or similar size boat. $100.00 for the pair. (The Typhoon had 6 blades, but 7 look scale enough),
Please e-mail me, or call, with any questions you may have at:
jkasinec@juno.com -or- (269) 323-3102 (Michigan)
Best Regards,
Tom Kasinec, SCM #1009
TKasinec
Return to SubSwap
