New In Box, 3 Futaba 4 Channel Systems on 75 Mhz
Postby Thor » Sun Jun 08, 2014 7:29 pm
I have too many radios, so I am going to sell a few off. I have 3 new in box Futaba 4YF-4 channel radio systems with servos. I paid $140.00 each. I'm asking $130.00 each. These are getting VERY hard to find.
PM me if you are interested.
You pay shipping.
This is the Futaba 4YF 4-Channel FM Radio System
with the R168DF Receiver and four S3004 Ball Bearing Servos.
FEATURES
All-channel servo reversing for more installation options
Transmitter and receiver NiCds made from genuine Sanyo cells can be
recharged simultaneously with the included 50mA overnight charger
Power and servo reversing switches are located down and out of the
way for convenience and to avoid accidental changes
The battery meter features one Green and one Red LED for easy-to-read
GO/NO GO status.
Ball bearing servos for smoother operation than standard servos
Spring loaded trainer toggle switch for instant "OFF"
Gimbals have knurled tops for a better "feel" on the sticks and to
prevent finger slippage.
One year limited warranty
INCLUDES
One Futaba 4YF 4-channel FM radio system with NiCd batteries, 120V AC
charger, frequency flags, neck strap, servo tray, switch harness,
S3004 servos, servo mounting hardware, transmitter and
receiver crystals and R168DF Receiver
SPECIFICATIONS
Transmitter:
Modulation Method: FM (Frequency Modulation)
Power Requirement: 9.6V NiCd battery
Current Drain: 180mA
Trainer Port: Micro
R168DF Receiver: (75MHz FUTL0833)
Length: 2.2" (55.5mm)
Width: 1.1" (28.5mm)
Height: .8" (19.8mm)
Weight: 1oz (28g)
Charger: FBC-8B(4)
Input: 120V AC 60Hz 4W
Output: Tx 9.6V DC 50mA
Rx 4.8V DC 50mA
Tx battery: 600mAh (FUTM1440)
Rx battery: 600mAh (FUTM1295)
Bands: 72,75MHz
S3004 Ball Bearing Servo FUTM0004
Speed: .23 sec/60° @ 4.8V
.19 sec/60° @ 6V
Torque: 44.3 oz-in (3.2 kg-cm) at 4.8V
56.8 oz-in (4.1 kg-cm) at 6V
Length: 1.59" (40.4mm)
Width: .78" (19.8mm)
Height: 1.42" (36mm)
Weight: 1.30oz (38g)
Connector: "J" type with approx. 5" wire
Re: New In Box, 3 Futaba 4 Channel Systems on 75 Mhz
Postby roberthusar » Mon Jun 09, 2014 10:03 am
Matt,
I need one. Please advise total with shipping to 91344.
Bob
roberthusar
Postby Thor » Mon Jun 09, 2014 12:50 pm
Bob,
Will do. Thanks!
Return to SubSwap
