SL-8 Receiver (Synthesized, 72/75MHz)
Postby kazzer » Mon Jun 23, 2008 2:07 pm
A synthesized ultra-light, ultra-small 8-channel receiver with advanced DSP signal detection, noise control and glitch suppression algorithms.
# Dual conversion, full range. Ultra narrowband (5kHz or better)
# Excellent sensitivity and IP3 performance
# Synthesized "crystal-less" operation
# Frequency selection through a modular, extremely rugged, reliable and easy to use programmer utilizing Sombra Labs' patented "1-Click"(TM) programming technology or our latest AFS ( Automatic Frequency Scanning) technology!
# AFS locks on the transmitter in less than 30seconds no matter what transmitter channel is used (for both 72MHz and 75MHz)!
# Three user selectable and programmable failsafe modes
# Compatible with most of the FM/PPM transmitters
# Automatic positive/negative transmitter shift detection
# Fully programmable servo pin assignments, any servo pin can be made to output any channel from Channel 1 to Channel 16
# Ability to store two user "Servopin-to-Channel" assignments
# Cascade mode: Two SL-8's can be cascaded together for up to 16-channel operation
# SL-8 will seamlessly cover 72MHz (Air), 75MHz (Surface) bands; no changes required to the product
# Most advanced DSP signal detection, noise control and glitch suppression algorithms
# Ability to turn the DSP filtering on or off using the Sombra programmer
# Fully FCC compliant.
# Dimensions: approx. 37mm x 20mm x 12mm (Vertical pin version)
# Horizontal and Vertical pin configurations
# Weight: approx. 9gms with full length antenna
# Designed and manufactured in North America
SL872 Sombra Labs Receiver 72/75 mhz $64.00
Order at -
http://www.caswellplating.com/models/transmitter.html
kazzer
Postby Rogue Sub » Mon Jun 23, 2008 6:55 pm
ohh a decent price aswell!
SL-8
Postby tincanrider » Thu Jul 03, 2008 11:25 am
Hi. I ordered and recieved the SL-8, the manual shows a "SHADOW PROGRAMMER" to set up/program the SL-8, do you carry/sell this item and what price. Keith
tincanrider
Re: SL-8
Postby kazzer » Thu Jul 03, 2008 11:59 am
tincanrider wrote:Hi. I ordered and recieved the SL-8, the manual shows a "SHADOW PROGRAMMER" to set up/program the SL-8, do you carry/sell this item and what price. Keith
You really don't need this unit for submarine setiings. (So Merriman tells me)
You can download the instructions on programming at
http://support.caswellplating.com/ look for downloads then R/C Models
kazzer
SL-8
Postby tincanrider » Thu Jul 03, 2008 3:19 pm
Hi.
OK, that is the same info that on came on the manual with the unit, on step 5: it talks about advance programming. Keith
tincanrider
Postby kazzer » Thu Jul 03, 2008 3:24 pm
Yep! Thats it!
kazzer
