REVELL U-BOAT VIIC & D Conversion ready
Postby kazzer » Thu Apr 24, 2008 12:58 pm
We have decided that the Revell VIIC &D does not need too much in the way of a 'fittings kit' as all the control surfaces (planes, rudder etc) are quite adequate. Of course, those crappy plastic props aren't worth a light, so we've obtained brass ones.
I've put together a great ACCESSORIES KIT, with props & shafts, batteries & charger, APC, SNORT, and almost everything you'll need to get this really neat boat into the water. All you'll need is patience and glue.
The Revell U-Boat VIIC & VIID
ACCESSORIES KIT
Propellers
R176-39 .79" diam 1/8" shaft Right 13000 max rpm Revell U-Boat VIIC & D $15.00
R176-40 .79" diam 1/8" shaft Left 13000 max rpm Revell U-Boat VIIC & D $15.00
SSS1 Stainless Steel Shaft - 1/8" Diameter x 24" Long 303 Stainless $2.70
DUM2013 1/8" Propeller coupling socket and nylon coupling rod $4.00
DUM2017 Drive Coupling Socket 1/8" $3.00
V1300X2 2 x Vislero 1300 ma 7.2V Battery With Free Charger $65.98
SUBES1 ES1 Switch $39.00
GSV1412N6V Micro Air Pump For Subs $17.00
AK1 Angle Driver With Failsafe $95.00
CUrrent kit and price at -
http://www.caswellplating.com/models/rviic.html
SD25VII D&E Sub Driver 2.5 Revell VII
So, all you need to do now is choose which Revell model you want to convert.
RV05045 German Submarine VIIC/41 Atlantic version $80.75
RV05015 German Submarine VII C "Wolf Pack" $80.75
And of course, if you want the Minelayer, you'll also need the Special Navy Conversion Kit.
SHY-72005 Special Navy Type VIIC-VIID Conversion Kit $34.00
See the models at http://www.caswellplating.com/models/rviic.html
Not all of this will be posted to to the Caswell site for a couple of days, but please pm me if you wish to order and I'll do it manually for you.
Shipping in approx 3-4 weeks.
kazzer
Postby kazzer » Fri Apr 25, 2008 9:02 pm
Amend the list to remove the batteries from the kit.
These MUST be purchased separately. (Shipping problems)
SO the kit is reduced in price.
kazzer
Re: REVELL U-BOAT VIIC & D Conversion ready
Postby OldNoob » Thu Jan 24, 2013 5:38 am
will the Special Navy 1/72 U-Boat Type VIID Minelayer Version conversion work on the revell Wolf-pack kit? i know the conning tower is different.
Any thoughts?
OldNoob
