OREGON SCIENTIFIC CAMERAS NOW IN STOCK
Postby kazzer » Wed Mar 26, 2008 9:12 pm
This camera has a Smart Card inside and will record approx 1 hour of high quality video.
It comes with velcro and rubber straps and is easily fixed to the hull of any mid to large size submarine.
Of course, it is not a transmitter, so to actually obtain the view from the periscope and drive your boat, use the Up-Periscope system in combination with this.
You can now order online at
http://www.caswellplating.com/models/oscamera.html
kazzer
Postby Mylo » Wed Mar 26, 2008 9:34 pm
So are you saying the cam can be coupled with some other electronic goodies to make it transmit in real time to an on shore monitor ?
....if so. .....hold on a sec, gotta find my credit card.
Mylo.
A Bridge Too Far (1977)
Mylo
Postby kazzer » Wed Mar 26, 2008 10:02 pm
Mylo
To transmit to a pair of virtual goggles, you need
http://www.caswellplating.com/models/camera.html
You can stand on the bank, and drive your boat as if you were on board, but the resolution is not so as good through the 'periscope'.
SO, you record the entire voyage with the high resolution camera which logs everything.
Now go get that card! :lol:
kazzer
Postby Mylo » Thu Mar 27, 2008 12:19 am
Whoa....whoa.....wait one damn minute ..... I can put on glasses that make me "see" from that camera ? Oh this just gets better. I've got some engineering to do to get that cam mounted on board. Next question, is there a micro cam small enough that I can mount in the periscope ? 3/8" long x 1/4" diameter ?
I don't understand what you said there. The 'periscope' cam is better, or this other bigger one ? I've got space to mount the big guy if it works better.
I will be looking further into that.
Mylo
Mylo
Postby kazzer » Thu Mar 27, 2008 8:52 am
The virtual goggles Image connect to the cameras receiver
the camera (that little black doohickey above) is about 3/4" x 3/4"
it fits inside a special WTC
which is strapped to the boats hull.
Alternatively, the receiver could be connected (via RCA jacks) to a monitor or some recording device.
You can see a video of the tv camera 'Up-Periscope' system.
http://www.caswellplating.com/models/images/camera.mov
Having said all that, the ATC 2K has much better quality video, but only records to a card. It does not transmit to the goggles.
ALso look at this Merriman report http://subpirates.com/viewtopic.php?f=32&t=3355
kazzer
Postby PaulC » Thu Mar 27, 2008 9:15 am
Nice explanation, Mike! :D
Postby Mylo » Thu Mar 27, 2008 10:49 am
Ah, I see....
Periscope cam for live feed to "seeing goggles" (with antenna above water)
ATC 2K for recording patrol. Mounted...wherever since it is only recording and not transmitting.
I DO get this stuff....eventually, ....just takes me a little longer than most.
I will be engineering my tower accordingly to accommodate both.
Mylo
Mylo
