New ThorDesign/Atomic Subs Electronics line
Postby ThorDesign » Fri Dec 31, 2004 3:56 pm
Atomic Subs and ThorDesign would like to announce 2 new items available after January 1, 2005.
The newest, most advanced pitch controller, the PC-4A has just finished 4 months of very intensive testing and is now in production. The PC-4A includes all of the solid state features found on our PC-2A, but now includes a dual axis sensor, which allows the user to literally install the device in almost any orientation and select which axis you wish to stabilize. The PC-4A also, includes the LED level indicators that ThorDesign pioneered on the PC-2. A sensitivity adjustment pot and a centering pot are both standard features of the PC-4A. The PC-4A also includes the progressive programming feature pioneered on the PC-2, which "learns" the characteristics of the boat as it is moving and predicts the next pitch cycle, which smooths the reponse of the device even more. The buffer is immediately refreshed if the predicted deflection does not match the sampled data and corrects immediately.
The second device is our new SC-20, 20 amp speed control with BEC. While still very compact we stuffed an amazing 400 steps of resolution in both forward and reverse for a total of 800 steps of resolution. This gives you amazingly precise control that was unheard of in the past. Low speed and high speed control are unsurpassed. Due to the SC-20s FET refresh rate of 10 kHZ, there is NO ANNOYING WHINE. We have run this board hard at over 20 amps and it does not even get warm.
The new PC-4A will list for $74.95
The new SC-20 will list for $64.95
Atomic subs will have a package deal with a substantial discount for buying the microsafe, PC-4A, adn SC-20 together. For more information contact Lyle at Atomic Subs!
Edited By ThorDesign on 1104524849
ThorDesign
Postby Graydon » Sat Jan 15, 2005 1:11 pm
Matt,
Is there any thought of doing a motor controller for brushless motors? I think the increased efficiency would provide extended run time for the subs. For small scale subs, this would allow the builder to use a smaller brushless motor too while maintaining a high level of performance.
Sincerely,
Graydon Stuckey
SC Member #2749
Fenton, MI
Graydon
Postby ThorDesign » Sat Jan 15, 2005 3:50 pm
At this time, there no plans to do so.
ThorDesign
