Revell Type 7 R/C, ok I will do it!
Postby D Manley » Fri Apr 09, 2004 6:46 pm
Due to the popularity of this exciting new kit; I have decided to produce an affordable R/C conversion package for this boat.
I expect to be able to offer this for approximately 85.00 and it should be as simple and efficient as my high end kits.
It will likely include gas ballast tank, forward dive plane output and linkage, aft rudder output and linkage, and access hatch in top of main compartment.
Will include two motors and 4.8v battery pack
This will NOT be a cylinder, it will be an easy to install, set of pressure bulkheads and I will try to make this as least invasive as possible.
You will need to supply speed control with bec, battery charger for 4.8v on board batterys, and a 4 or more channel radio.
Now the bad news, I do not know when I will have this ready for ordering as I have other more pressing projects to tend to, but I hope to have it available this fall.
Small World Models.
D Manley
Postby ThorDesign » Fri Apr 09, 2004 7:41 pm
Dave,
Already well underway at ThorDesign and Atomic Subs. Lyle Jansma and I have been working together on this project, but have tried to keep it quiet. Your approach is somewhat different than ours as ours will come with a cylinder with electronics.
Edited By ThorDesign on 1081554222
ThorDesign
Postby Novagator » Fri Apr 09, 2004 8:24 pm
Cool! :cool:
John Cottingham
Sub Committee Member #2721
Novagator
Postby Captain Nemo12 » Fri Apr 09, 2004 8:37 pm
Right back at ya! :cool:
-Jurgen Prochnow, Das Boot.
http://eisernwolf.blog.com
Captain Nemo12
Postby Jefff J » Fri Apr 09, 2004 10:02 pm
hello fellow Revell VII fans...
I am glad the intrest in this kit is so high. I know any after market upgrades to this kit are going to be a hit. And a gold mine to the guys that come up with them. I have 2 kits on order as I type. Good luck to you both. And a big thanks from me and the rest of us Revell'ers. :D Jeff Jones
One things for sure, they won't be expecting us.... s/c# 0258
Jefff J
Postby Casey Thrower » Fri Apr 09, 2004 10:54 pm
What kind of glue should you use on this boat so it won't come apart and also, how do you plan on keeping the deck on to rc it?
Casey Thrower SC Member #1675
Casey Thrower
Postby MIT » Sat Apr 10, 2004 8:54 am
Where can one order this kit from ?
Nick
MIT
Postby Jefff J » Sat Apr 10, 2004 10:07 am
Casey, hey I know this one, good old fashion Tester glue, the kind you used as a kid!!! This will hold the plastic together in water. You can order these models from internethobbies.com, but you can expect a delay..... good luck Jeff J.
Jefff J
Postby Jefff J » Sat Apr 10, 2004 10:10 am
if I glue the deck on, (brass) I was going to try 2 hr epoxy, thats if I split the hull, will have to wait until I get to that point. Or see what is working for some of the other guys. JJ
Jefff J
Postby TennesseeJim » Sun Apr 11, 2004 9:51 am
Great idea on the upgrade kit(s)!
Keep us up-to-date on the status and let us know when they are available.
- Jim
TennesseeJim
Postby safrole » Fri Apr 16, 2004 12:52 am
Rumor has it (from a post by Torsten in the R/C forum) that Norbert Bruggen is going to hit a show on the 21st with a Revell kit. He said he will bring back a review after he attends.
Check out the link.
http://www.modelluboot.de/KITS/VII/VIIc.html
safrole
Postby raalst » Fri Apr 16, 2004 4:17 pm
I'll have a look as well.
be there on saturday (21 is wednesday)
anybody else going ?
Postby comcardiv1 » Fri Apr 16, 2004 8:30 pm
Greetings, group
I just bought one of these kits this morning--not a bad job from our friends at Revell/Germany. I was thinking about what it would take to make it operational, but not being a sub guy I thought I'd check this board first. Glad I did--I'll be awaiting any announcements of aftermarket upgrades with great interest...
Gene Kirkland
comcardiv1
Postby boatbuilder1 » Fri Apr 16, 2004 11:22 pm
when will people learn .....................................
Dave Merriman has warned us all epoxy will trun to jelly if imersed too long
try j b weld or pc7 marine epoxy (yes epoxy) formulated for imersion hence the word marine
charlie
its all relative
boatbuilder1
Postby JWLaRue » Sat Apr 17, 2004 11:51 am
Chuck,
Not strictly true.
Epoxies that have a cure time of something like less than 90 minutes will soften in water. Those with longer cure times will not be a problem for us.
I use several epoxies that have given me good service. West Systems and Anchor Bond (90 minute) being the two I most often use.
Recently I have been experimenting with a Scotch-3M epoxy (I don't have the part number handy) that has an even longer cure time and is supposed to be good for bonding different materials together...like plastic hulls and etched brass decks..... :) When it cures it is not the hard, brittle substance that most epoxies are, it seems to retain a slight amount of 'give' to it. This could be just what we need!
