Typhoon - made of paper
Postby libor » Fri Jul 29, 2005 9:09 am
Hi, what do you think of submarines made of paper?
I am luckily finishing with one in few weeks. Photos on my Subcommittee home web page:
http://www.subcommittee.com/SubComm....rID=224
Any comments welcome.
Enjoy.
Libor
Edited By libor on 1141750386
libor
Postby petn7 » Fri Jul 29, 2005 9:49 am
I'm impressed. Is this a kit?
petn7
Postby Bob the Builder » Fri Jul 29, 2005 10:33 am
That is very impressive. Well done.
I can hardly believe that its paper.
Postby Gerwalk » Fri Jul 29, 2005 10:36 am
Impressive! Kudos!
What is the scale?
The frame is made of wood?
Pablo
Gerwalk
Postby Mkeatingss » Fri Jul 29, 2005 2:02 pm
Now for the big question. Where do you get one??? And how much are they?
Mike
Mkeatingss
Postby U812 » Fri Jul 29, 2005 3:55 pm
I'd have to say the same. Very well done!
U812
Postby tabledancer » Sat Jul 30, 2005 11:39 am
Very impressive,what are the frames made of.Is it glued with a waterbase glue or are the frames press fit.I like the Akula to,thought about doing one myself,keep us informed on the build.
TD :D
tabledancer
Postby libor » Mon Aug 01, 2005 3:32 am
petn7 wrote:I'm impressed. Is this a kit?
Yes, it is a kit made in Poland. Name "Czerwony Pazdziernik" like the Red October. Made by Adora Model. Could be bought at e.g.:
http://www.gamahobby.com/x_C_Dz__P2_5510026.html
Libor
libor
Postby libor » Mon Aug 01, 2005 3:36 am
Gerwalk wrote:Impressive! Kudos!
What is the scale?
The scale is 1:200.
Because I thought I could better handle the frame which is 2 mm and 1 mm thick, I have decided to use balsawood which is easer to cut... little copromise, all other parts are paper.
Libor
libor
Postby libor » Mon Aug 01, 2005 3:43 am
Mkeatingss wrote:Now for the big question. Where do you get one??? And how much are they?
Mike
I bought my when I was on model exhibition in Poprad, Slovakia. The Polish modelers usually bring with them a couple of kits to sell. The price was 200 Slovak crowns what is cca 7 USD.
Since there are several inaccurances (e.g. the size of holes for rockets in frame) be carefull when glueing ;-)
On the internet I found this site:
Look wor the "CZERWONY PAŹDZIERNIK" + model in google and you will sure find some supporters in Polland. In case you have some problems I can help. Just let me know.
Libor
libor
Postby libor » Mon Aug 01, 2005 3:55 am
tabledancer wrote:Very impressive,what are the frames made of.Is it glued with a waterbase glue or are the frames press fit.I like the Akula to,thought about doing one myself,keep us informed on the build.
TD :D
I used balsawood to harden the ribs. I was supposed to use 2mm and 1mm thick paper, but I found out that it is quite hard to cut "nicely" such a thick paper, so I used balsawood, which is rather expensive but - what a pleasure to work with.
And I used noncolored adhesive usually used for paper and wood work. Since It is good to water down the glue, all glues which are water based are good. For some quick work I used quick drying adhesive.
Libor
libor
Postby libor » Mon Aug 01, 2005 4:01 am
... thank you very much for all your replies. The last progress is photographed and published on my Subcommittee site.
L.
libor
