Revell Type VIIs - How outerdoors , & shutters operated
Postby Mkeatingss » Sun Dec 12, 2004 4:37 pm
On the Revell model, it allows you to show the outer doors open or closed.
Now. On US boats the shutters slid forward, a distance equal to the diameter of the door plus the hinge displacement, as the doors opened.
The distance from the leading edge of the shutters, on the Revell, to the nearest edge of the bow seems too short, to allow that. So, how did the Germans get the shutter out of the torpedo path, when they opened the doors? Or did Revell mess up there, and we're stuck with it?
Help?!?!?
Mike
Mkeatingss
Postby JWLaRue » Sun Dec 12, 2004 5:39 pm
Hi Mike,
The bow torpedo doors on the Type VII were hinged at the front. They were simply opened by moving the rear edges inwards to clear the tubes.
Postby Mkeatingss » Mon Dec 13, 2004 12:32 am
Thanks, Jeff.
But, I also need to know how it was done. Was it linkages or what?
I assume that the shutters had to move in, for some distence, before the outer doors opened. And the doors would have to be partially shut before the shutters began to move back out.
Are there any drawings, that show how the system operated? I'll can email you a drawing of the Door-shutter arangement on a 637, if they'd be of use to you. But I've got nothing on the German system.
Mike
Mkeatingss
Postby JWLaRue » Mon Dec 13, 2004 11:34 am
Hi Mike,
The hull shutters were opened/closed along with the outer tube doors (also called "bow caps"). Looking at the linkage, it does not appear that there is any "slack" in movement between the two.
I've not seen any diagrams or drawings of this detail, but there are photos that show this. If you're interested in some photos, drop me an e-mail and I'll see what I can find.
Postby JWLaRue » Mon Dec 13, 2004 11:36 am
Hi Mike,
Postby Mkeatingss » Mon Dec 13, 2004 2:42 pm
Jeff, I emailed you at your old compaq address. It got kicked back. Can you send your new one to << mkeatingss@cox.net >>
Mike
Mkeatingss
Postby JWLaRue » Mon Dec 13, 2004 5:19 pm
Mike,
That old address is still functional. I'm guessing that you may have 'mispelled' my first name....? That would be jeffrey.larue@compaq.com or [email]jeffrey.larue@hp.com.[/email] :)
I'll drop you a quick e-mail.....
