Modifying the USS Andrew Jackson (Revell)
Postby spike_57 » Thu May 20, 2004 10:56 pm
I am preparing to build the 1/200 USS Andrew Jackson from Revell. I would like to use the clear hull section from an old USS Thomas Jefferson kit that is available by auction. I know the subs are of different classes (Lafayette vs Ethan Allen), but would it fit?
Any help would be appreciated.
Thanks,
Spike_57
spike_57
Postby mike byers » Fri May 21, 2004 6:57 am
Obviously they must have the same scale to begin with.
The lower hull may be the same diameter 33', but - the upper hull has a different configuration. These are two different classes of boat.
But it all depends on how accurate the kits are, so - it may work.
Unfortunatly you will just have to try.
De Profundus
Mike Byers
SC# 2486
mike byers
