1/72 Nautilus
Kevin Price
Re: 1/72 Nautilus
Postby Rogue Sub » Sat Feb 13, 2010 8:58 pm
Here is a bit of excitement The lower half of the 571 is complete.
Re: 1/72 Nautilus
Postby raalst » Sun Feb 14, 2010 10:01 am
sure is a nice way to produce a new hull in a hurry.
is the result smooth enough or do you need a bit of sanding still ?
Re: 1/72 Nautilus
Postby Rogue Sub » Sun Feb 14, 2010 10:14 am
Yes very slightly
There is a final pass that only takes off thousands of an inch and gets it very close
Here is a shot of the top starting. The bottom is complete.
Re: 1/72 Nautilus
Postby Rogue Sub » Sun Feb 14, 2010 10:10 pm
Here are few more shots of the top coming together.
Re: 1/72 Nautilus
Postby Rogue Sub » Tue Feb 16, 2010 6:56 pm
Had to step away from this for a few days for family business but I am back home now and have lots of pics to share!
Re: 1/72 Nautilus
Postby Rogue Sub » Wed Feb 17, 2010 10:47 am
Here is a shot of the propeller support fins as they came out. The plan is to cast these parts as part of the hull and as one piece with the bearings in place so that the end user wont have to knock their brains in trying to get everything lined up proper.
Re: 1/72 Nautilus
Postby Rogue Sub » Fri Feb 19, 2010 2:28 pm
There have been a requests to have the kit supplied with the polar ice sail so one is getting put together. In the end you will just request which sail you want with the kit or both.
Re: 1/72 Nautilus
Postby Rogue Sub » Sat Feb 20, 2010 8:56 pm
Now the polar sail is complete and this conclude all of the cnc work with this boat. Pics of the props will be up soon.
Re: 1/72 Nautilus
Postby Rogue Sub » Mon Feb 22, 2010 9:28 pm
There has been some questions as to the actual size of the boat due to the large size of the CNC. Here is a pics next to a ruler and a shot of both sails.
Re: 1/72 Nautilus
Postby Rogue Sub » Thu Feb 25, 2010 8:41 pm
Here is a shot of the props in process. The blades still require shaping.
Re: 1/72 Nautilus
Postby Rogue Sub » Wed Mar 03, 2010 10:07 pm
Propellers are coming together nicely now
Re: 1/72 Nautilus
Postby Rogue Sub » Fri Mar 19, 2010 7:49 pm
Here is a shot of the propeller support fin with prop mounted on a 1/8" Stainless shaft. Everything fit first time with zero modifications.
Re: 1/72 Nautilus
Postby Timothy Guest » Sun Mar 21, 2010 4:16 pm
Looking good. I predict this will be a hit with all the first generation nuc boat fans, including myself. Looks like I'll just have to get one of these.
Timothy Guest
Re: 1/72 Nautilus
Postby Rogue Sub » Thu Mar 25, 2010 8:54 pm
Perhaps you will make it to Groton for the fun run and you can join the group picture we are planning at the Nautilus.
Re: 1/72 Nautilus
Postby Bigdave » Thu Apr 22, 2010 12:40 pm
Any new updates Kevin? :?: BD.
Return to Rogue Sub Works
