1/48 Type XXI now available
Kevin Price
Postby Myles Yancey » Thu Aug 13, 2009 10:12 pm
Hi everyone talking about the 1/48 scale Type XXI Kit being produced by Precision Patterns and Rogue Models, this kit was originally produced by Doug Badgley,Then sold I believe to Matt Thor who in turn made some improvements to the kit and then sold it to Paul Crozier at Warfish Models who made more improvements to the kit.
We will be putting together and article for the SC Report on how we built the Type XXI kit.
We will be explaining what we did to build the kit in detail so that those of you that are thinking about building this kit will at least see how we built it.
We will also be including and article on what we will be doing for a WTC for the kit.
At the same time we will be installing a set of resin cast parts for the kit, the first parts will be the flood vents. These parts were originally made by David Tanguy.
The second set of parts will be Resin cast deck grates and hatches, Which were originally created by David Tanguay, which were developed from Jeff LaRue’s brass deck for the Type XXI.
Thanks Myles
Myles Yancey
Postby Rogue Sub » Fri Aug 14, 2009 8:56 am
I am also having a build instruction for this boat made so that new owners will have a guide for their build. It will be included with the kits once it is completed.
Postby Rogue Sub » Fri Aug 14, 2009 9:03 am
Update:
Shipping will be $25 within the continental US
Type XXI
Postby tincanrider » Fri Aug 14, 2009 1:27 pm
Hi Kevin.
Will you be offering/selling the instruction seperatley? I have a XXI from Paul C- but not started yet.
Keith
CPO ret.
tincanrider
Postby Rogue Sub » Fri Aug 14, 2009 1:31 pm
I have not considered that yet. It will be a little bit before they come out though as it takes time to make
Postby Rogue Sub » Fri Aug 14, 2009 8:37 pm
Tincan
If you need instructions (when completed), updated drawings, etc just let me know. I would be glad to help you out. Sorry I did not really answer your question earlier.
Postby fgroza » Sat Aug 15, 2009 7:57 pm
Kevin,
I saw Doug at Carmel in '05 with the XXI and loved it. Does it still retain the rack style of steering? Also, is the wtc going to be based on RCAB type of operation?
Just picking your brain, what is left of it!!!! Just kidding. Hope your dad got the boat working after getting home from Carmel. Had a fun time there and glad to have met you and your father.
Frank
fgroza
Postby Thor » Sat Aug 15, 2009 8:47 pm
Frank,
We are using the timing belt drive system for the rudder. It is clean, reliable, and very easy to install.
The WTC is not an RCABS system.
Postby Rogue Sub » Sat Aug 15, 2009 9:26 pm
Like that guy said.
Hey frank didn't know that was you. I swear the name tags should have our post names on them.
No luck on the type 7 needs a much larger ballast tank. It'll be going again soon enough.
type XXI
Postby tincanrider » Sat Aug 29, 2009 11:59 am
Hi Kevin.
From your post from the 14 th, when you get the manual/instructions made up I would like to get a copy. Thanks Keith
tincanrider
Return to Rogue Sub Works
