New Pitch & Depth Controller Available!
Matt Thor
Postby Thor » Mon Mar 08, 2010 4:24 pm
New Pitch and Depth Controller!
Holds the submarine at a depth set at the transmitter by controlling the planes.
Has 2 independant outputs (bow and stern plane) and a separate On/half/off input.
Contains pressure sensor, inclinometer and microprocessor.
Typ: Plug-in-between device.
takes voltage from receiver battery
dimensions: open PCB with socket
60 x 38 x 24 mm
weight: 21 g
Voltage: safe 4.0 - 6.5 V
possible 3.0 - 12 V
consumption: 7.5 mA at 4.8 V
pressure: possible:
Vacuum - 2 bar abs
working: ambient atmosphere - +0.1 bar
= 0 - 1 m depth
Re: New Pitch & Depth Controller Available!
Postby Myles Yancey » Mon Mar 08, 2010 4:41 pm
Looks great, what would be the cost?
Myles Yancey
Postby Thor » Mon Mar 08, 2010 4:52 pm
Will have that soon....working on the exchange right now....
Return to Precision Pattern
