Custom Replica's 66 inch nautilus qutestion
Nautilus, Seaview, and more
Postby Bob the Builder » Tue Mar 08, 2005 11:50 am
Novagator wrote:Bob,
where are you control levers for the rudder and the rear dive planes?
This should shed some light...
This picture was taken before I repainted her, so the linkages are far better concealed under her paint now. If you look at the photo that I posted at first, you can see the rudder linkage at the bottom of the rudder. It's just a tiny arm and rod, barely visible unless you look closely. The majority of the linkage is run within the tail.
Bob
Postby Novagator » Tue Mar 08, 2005 1:42 pm
Thanks bob,
One more question, do you run the rudder control rod through a tube inside the tail or did you just dig out a channel and then cover it with without a tube for the rod to slide in.
John Cottingham
Sub Committee Member #2721
Novagator
Postby 99-1073702857 » Tue Mar 08, 2005 4:21 pm
Hi Carcharadon...I watched your videos, and the four foot boat looks like the just the ticket ! I also have sent you an email, and hope that you can provide some details on the construction of your boat. Bob Martin has built the finest model of Nautilas that I have ever seen, but for my purposes, your propulsion system and general boat layout will probably work a little better. Thanks very much. :)
99-1073702857
Postby Carcharadon » Tue Mar 08, 2005 4:46 pm
Chuck, got your email and will respond. Have to agree with you, Bob has a beautiful boat there.
Carcharadon
Postby Novagator » Tue Mar 08, 2005 5:23 pm
Carchardon,
You got any pics of your sub out of the water and the internals?
john
John Cottingham
Novagator
Postby Carcharadon » Tue Mar 08, 2005 6:39 pm
John some pictures on the members home page.
think this will work
http://www.subcommittee.com/SubComm....rID=184
Carcharadon
Postby Novagator » Wed Mar 09, 2005 10:45 am
Thanks, got any pics of the stern?
John Cottingham
Novagator
Postby Bob the Builder » Wed Mar 09, 2005 11:37 am
Novagator wrote:Thanks bob,
The pushrod itself is 1/16" diameter, and it runs inside a 1/8" ID square tube. Square was used so that it would sit inside the routered channel easier and cover better afterwards. It meant redoing about fifty rivets or so, but it was well worth it in the end. The only evidence of the surgery is the short length of pushrod between the tail and the rudder...
Postby Novagator » Wed Mar 09, 2005 12:53 pm
Looks Great!
John Cottingham
Novagator
Postby Carcharadon » Wed Mar 09, 2005 4:37 pm
Novagator wrote:Thanks, got any pics of the stern?
Done
Carcharadon
Postby Novagator » Wed Mar 09, 2005 9:11 pm
Done
Thanks, so you use thrusters on both sides of the hull?
John Cottingham
Novagator
Postby Carcharadon » Thu Mar 10, 2005 7:42 am
I tried a single but the ship would always turn one way or the other. Two solved that.
Carcharadon
