Tintin's submarine
Nautilus, Seaview, and more
Tintin's submarine
Postby modelnut » Mon Mar 31, 2014 9:24 am
Where can you get a kit, model or hull of Tintin's shark submarine?
- Leelan
modelnut
Re: Tintin's submarine
Postby Sub culture » Tue Apr 01, 2014 9:27 am
You make one from scratch. Not a difficult hull type to turn on a lathe, being spindle shaped. Or you could try traditional plank-on-frame (known as lapstrake in U.S) or bread and butter techniques if a lathe isn't available.
Postby JWLaRue » Tue Apr 01, 2014 9:52 am
Sub culture wrote:You make one from scratch. Not a difficult hull type to turn on a lathe, being spindle shaped. Or you could try traditional plank-on-frame (known as lapstrake in U.S) or bread and butter techniques if a lathe isn't available.
...known as plank-on-frame here in the U.S. as well.....
Postby Sub culture » Wed Apr 02, 2014 5:39 pm
Fair enough. A plank on frame construction would be straightforward enough, as the bulkheads can be drawn out with a compass, and you could use a piece of tubing for the keel, ensuring accurate alignment. This boat is streamlined and agile, so a good fun subject to build and run.
Postby modelnut » Sat May 03, 2014 8:23 pm
modelnut
Postby modelnut » Fri May 30, 2014 8:54 am
Trying a quick and dirty static build in 72 scale. I picked up a Messerschmitt Me 262 B-1a U1 and I'm basing the sub on that.
modelnut
Postby modelnut » Fri May 30, 2014 10:01 am
Last tweak!
The aft diving planes needed updating.
modelnut
Postby Ralph --- SSBN 598 » Fri May 30, 2014 10:03 am
Looks a lot like a ME-262 fuselage.
Frames and planks should work just fine to duplicate on this subject.
Or frames and foam.
Cover with fiberglass then remove foam.
Make sure to remove the frame centers first. It's not easy after the glass is in place.
Ralph --- SSBN 598
Postby modelnut » Wed Jun 04, 2014 2:01 pm
Thanks, Ralph,
I'm kitbashing a 72 scale styrene kit right now. And I'm tweaking as I go. There are plenty of models of the ME-262 in many scales.
Here is what I have done so far.
I'm just starting to work on the mouth of the shark today.
modelnut
