Centrifugal pump in pressurized ballast system
Postby redboat219 » Sun Nov 02, 2008 11:17 am
Posted this question on SP a couple of months ago.
Can I use a centrifugal type pump on a pressurized ballast system?
redboat219
Postby Sub culture » Sun Nov 02, 2008 4:30 pm
Indeed you did, and I thought you had your answer.
The bottom line is, yes you can, but they won't work as well as a positive displacement pump, and they will probably fail after a time.
Postby redboat219 » Mon Nov 03, 2008 2:11 am
Yes I did. I posted it for the guys here who don't go to SP. :D
redboat219
Re: Centrifugal pump in pressurized ballast system
Postby celinaaniston86 » Fri Dec 23, 2011 3:06 am
Well, I don't have experience with centrifugal pump but I have used some kinds of water ballast over the many years.
And they are still very much in use & yes they do in work.
Submersible Well Pumps
celinaaniston86
