RX battery - Querie
Postby David H » Sat Feb 22, 2003 1:38 am
Dear all,
Can i run a Reciever off a 6v 1.3 am Sealed lead acid battery?
regards,
david H
David H
Postby Wheels » Sun Feb 23, 2003 7:07 pm
David...You can run your radio off of a 6 volt sealed lead acid battery. It will make the servos run faster and be a little stronger too. If this is the main battery for the model I would not recommend doing it because if the battery dies your radio dies too, and then you loose control. I have limped in with a low main battery, because my radio was fed off a secondary battery.
Jim Wheeler....."Life is not measured by the number of breaths we take, but by the moments that take our breath away."
Wheels
Postby David H » Mon Feb 24, 2003 6:42 am
Dear wheels,
Thanks for that advice. It would just save me alot of time if I could simply use a lead acid battery then I would'nt have to open up the WTC all the time. I could hook up the lead and the reciever would come to life.
So 6v won't fry the Reciever.
I have some stuff on the Deep down Aussie site you may want to look at. I have a Yuushio, Akula and an L.A
regards
David Hughes. :)
David H
