How to make cheaps seals ! - For the do it yourself guys !
Postby ThierryC » Tue Apr 15, 2003 8:25 pm
A friend of mine showed how to make make water tight seals for pushrods coming out of the WTC and that is so easy and cheap that I thought I should share it here.
First you need a Pneumatic fitting, available at any car store, diameter matching the diameter rod, here 1/8
Edited By ThierryC on 1059701724
Sub-Systems
ThierryC
Postby ThierryC » Tue Apr 15, 2003 8:28 pm
Open it and remove the compression fitting inside
Edited By ThierryC on 1059701769
Sub-Systems
ThierryC
Postby ThierryC » Tue Apr 15, 2003 8:29 pm
Then you need to carefully bore the inside of the fitting to the diameter needed, here 1/8. A hand drill works, a drillpress is better.
Edited By ThierryC on 1059701800
Sub-Systems
ThierryC
Postby ThierryC » Tue Apr 15, 2003 8:30 pm
Once the inside is nice and smooth, fill up the fitting with lithium grease
Edited By ThierryC on 1059701831
Sub-Systems
ThierryC
Then put a 1/8 oring on the opening
Edited By ThierryC on 1059701856
Sub-Systems
ThierryC
Postby ThierryC » Tue Apr 15, 2003 8:31 pm
Finally screw back the top of the fitting in place, make sure to squeeze the oring tight but not too tight
And Voila : a perfectly watertight seal for your pushrods.
Total cost $12CDN for 5 of the 1/8 (including oring) and 2 of the 3/16 (including oring
Edited By ThierryC on 1059701898
Sub-Systems
ThierryC
Users browsing this forum: Google [Bot], tompinnell
