Name that model kit?
Re: Name that model kit?
Postby JWLaRue » Thu Aug 23, 2012 10:23 am
Okay, let's see if we can put Kevin out of his misery. :mrgreen:
....Combat Models hull?
Postby Bigdave » Thu Aug 23, 2012 10:57 am
Nope!
Good guess though.
It was a complete kit.
Hint try the hull numbers for clues.
BTW I like your Kevin idea!
Postby Bigdave » Mon Aug 27, 2012 9:01 am
I guess you all gave up.
O well! :cry:
I will post the info later.
One more hint. The sub is Italian.
The kit and the boat. BD. :D
Postby JWLaRue » Mon Aug 27, 2012 9:09 am
I think I know the answer. I found it in your regatta write-up.....
Postby Bigdave » Mon Aug 27, 2012 12:04 pm
Sounds like someone may be disqualified! :mrgreen:
:wink: :lol: BD.
Postby JWLaRue » Mon Aug 27, 2012 12:17 pm
Yea, well.....even with that 'help', I couldn't find anything on the 'net about it......
Postby Sub culture » Mon Aug 27, 2012 3:10 pm
Scoop out the old innards, glue up the crack in the hull, bung a cylinder in, and you're back in business!
Postby Bigdave » Mon Aug 27, 2012 6:29 pm
I am not supprised Jeff.
I only have seen one a few years back on ebay and the guy had the wrong name on it.
I don't think he knew what it was. :?
The kit was sold and imported by Polks back around 1980.
It was from a company in Italy called ISPD models.
I bought mine through Polks but it was also sold through Dynamic models who got them from Polks.
Here is a scan of the page from the 1981 Dynamic catalog that shows the kit.
The hull came in a clear plastic poly material.
You could basically build it clear if you wanted as is shown by the Dynamic add.
I remember seeing the same clear built boat at the big Polks store in NYC.
It used a ballast tank with a rubber membrane inside that expanded as the water was pumped in.
The top of the lower hull section had a steel sheet that you cemented to it that had three cutout sections.
There were covers that screwed down over the openings with rubber gaskets.
The boat was quite heavy for its size as it was a dry hull boat.
It was only semi scale and could be made to look like most WW2 subs.
Mine was painted like the Italian boats of the day.
I think they started life as Type 2 German boats.
Jeff may know more about that.
It was a cool boat for its day. 8) BD.
