F/glass hull availability...
Postby U-33 » Mon Jan 03, 2011 5:16 am
Anyone know if there's a replacement fibreglass hull available for the 1/144th Trumpeter Seawolf? Or something very similar?
I'd like to replace the plastic one on the Dragonfish with something less flexible than the original kit version.
Rich
U-33
Re: F/glass hull availability...
Postby Sub culture » Mon Jan 03, 2011 2:06 pm
No. But you can stiffen the hull you have using various methods.
You can solvent weld in extra ribs, or even a spine running lengthways from some plasticard. A box section would make things very rigid- think of a sill structure on a monocoque car bodyshell.
Or you could key up the surface and glass it inside.
