Bursting Pipe Joint?
Postby Ramius-II » Fri Sep 17, 2010 9:39 am
In movies when a sub is in trouble you always see pipe joints or pipes bursting. What is the function of theses pipes?
Thanks, Ed
Re: Bursting Pipe Joint?
Postby tabledancer » Fri Sep 17, 2010 11:58 am
To get the actors wet and make it look like they do something besides looking pretty!!!!!!!!!
TD :lol: :lol:
tabledancer
Postby Rogue Sub » Fri Sep 17, 2010 8:21 pm
Good call!
Its just the movies and you have to take it at face value.
Postby Ramius-II » Fri Sep 17, 2010 9:00 pm
While it is easy to agree there was a special on training submarine crews and part of the training they showed were guys installing patches on broken / leaking pipes which gave the impression that pipes could have problems. Or am I just confusing one thing with something else?
Postby Rogue Sub » Fri Sep 17, 2010 9:14 pm
We are trained to fix pipe burst yes. Could be any seawater or hydraulic system that it happens to though. A few scenarios are exceeding test depth and pipe pressure ratings and bursting them or a close aboard explosion causing them to rupture. In these cases we might need to patch a pipe or secure the system all together... Does that help?
Postby Ramius-II » Sat Sep 18, 2010 4:09 am
Yes a little I think. Hydraulic systems are understandable and that would be I would imagine oil. What systems use seawater? The ballast system, showers, toilets, engine cooling or are there other uses?
Postby Rogue Sub » Sun Sep 19, 2010 10:41 am
airconditioning, electronics, main engine condeners, diesel seawater cooling, toilet...lots of stuff
Postby Ramius-II » Sun Sep 19, 2010 11:28 am
Thanks very much! I was asked since I am working on a model and I did not feel I had very good asnwers so I thought it best to ask the people who really know!
Best, Ed
