Can anyone help please?
Postby tompinnell » Fri Jul 30, 2010 9:32 am
Hi, I paid my membership a couple of days ago but still can't log in to the members area. Does anyone know who I need to talk to or if that is correct? I haven’t received a membership number or anything so I’m a little confused what I’m meant to do. Is I probably my fault must of missed summit when I paid my membership. Thank you for your help.
Regards Tom
tompinnell
Re: Can anyone help please?
Postby greenman407 » Fri Jul 30, 2010 9:44 am
Hello tompinnell, welcome! I am not someone of authority on this site but sometimes I have the same problem. Try this. Go to the message board and click on it. If you want to sign in , press the "postreply" button and a window will open up where you sign in. Sign in there and then back out, it should work. If not , one of the officers will have to fix it for you. Be patient, they will help you. Kind regards
Postby tompinnell » Fri Jul 30, 2010 9:59 am
Thank you I will give it a go, I wasn't sure if I had done something wrong not in any rush just thought I would ask. Thank you Tom
tompinnell
Postby JWLaRue » Fri Jul 30, 2010 10:29 am
Hi Tom,
First...welcome aboard!
The members area of the main web site uses a different set of login credentials. To date, the SC hasn't been able to make the forum and member's area use the same credentials. What you need to do is to send an e-mail to the SC webmaster (webmaster@subcommittee.com) and ask that you have a member's account created. Paul will need your membership number.....which you may not have if you haven't received your first issue of the SubCommittee Report. If you don't have it, please make sure that you provide Paul with your name and address that you provided when joining....he can then check the membership database.
Let us know if you have problems!
Jeff
Postby tompinnell » Thu Aug 26, 2010 3:57 am
Hi, I emailed the following asking about my membership (webmaster@subcommittee.com) but I still haven’t had a reply, it’s been 10 days. I understand it may take a while and it’s the holiday season but getting a little concerned as it was the 20th July that I paid via PayPal. If anyone has any info on who I can contact would be grateful.
Regards Tom
tompinnell
Postby greenman407 » Thu Aug 26, 2010 9:32 am
Sorry about the delay. Im going to email a few people this morning and draw their attention to this. Hang tough! :D
Postby tompinnell » Thu Aug 26, 2010 10:50 am
Not a problem I wast sure what to do thank a lot Tom
tompinnell
Postby Rogue Sub » Fri Aug 27, 2010 9:28 pm
Actually I am the one he needs to talk to. I have given you access to the area.
Postby tompinnell » Mon Aug 30, 2010 8:36 am
Thank you all of you for your help regards Tom
tompinnell
