Postby Racer » Wed Aug 08, 2012 6:49 pm
Hey Chuck,
Here is a link to the documentation on the connectors.
http://www.souriau.com/fileadmin/Souria ... Series.pdf
These are a twist-lock bayonet type connectors with an internal gasket making them waterproof.
They are solid locking and seem very quality.
I purchased them from Digikey.
Tom Mihelich
Racer
Postby Casey Thrower » Wed Aug 15, 2012 10:12 am
More, more!
Casey Thrower SC Member #1675
Casey Thrower
Postby Racer » Tue Aug 21, 2012 6:21 pm
I have made a fair amount of progress over the past few weeks and thought it was time for an update.
The first pic here shows the new CNC cut fittings for the Control Module.
I want to thank Jeff LaRue for helping me out with some of the finer details for the discharge and suction grates.
Jeff's fine photo etch parts which he sells for the 1/96th scale boats was just to small for these fine hole details.
We both thought even at 1/48th scale might not work but as you can see...it worked fantastic.
In order to drill holes at roughly the size of a human hair, I had to dig deep into the net to find these type of drills.
I got lucky and found a site which specializes in these type of micro drills made for PCB board work.
I bought 3 of them and loaded one into the CNC and crossed my fingers.
I was able to get these right on the first try without breaking the bit. :D
I am just amazed that a big machine like this can drill and mill such a delicate piece....just amazing.
Also hot out of the machine shop facility is the outer hull for the Control Module!
The fit to the aft section mated just as designed.
Now it is time to finish up the milled exterior detail parts and then move into the inside with the WTC for this section.
Lot's to do....
Tom Mihelich
Racer
Postby JWLaRue » Tue Aug 21, 2012 8:54 pm
Tom,
They look great with all the correct holes!
Postby Casey Thrower » Thu Sep 27, 2012 11:30 pm
I hate how builds get interesting then stop. :evil:
Casey Thrower
Postby Racer » Fri Sep 28, 2012 2:16 pm
Well, it is far from stopped.
I am currently recovering the costs from what has been done thus far before going any farther.
I am back in the design phase again on this latest section.
Tom Mihelich
Racer
Postby Wayne Frey » Fri Sep 28, 2012 8:51 pm
This..is an impressive build. Even down to the little guys standing around!
I have not posted my Borei build in a while, but it is going along slowly. I will post pictures when it looks like something changed. I have a lot of hours in fit of the halves, but waiting to get the tube in primer before posting. It wont be long.
However, my methods are pretty loose and basic. This build is one of the most precise,detailed, I have seen.
I do like following this one. No matter what I do, this build will badly out class mine for sure.
Awsome!
Postby Casey Thrower » Fri Oct 05, 2012 1:56 pm
Tom, would you consider making some of these grates and ballast vents for the 1/48 Moebius Skipjack? I think they would work as is.
Casey Thrower
Postby wlambing » Fri Oct 05, 2012 4:48 pm
Casey,
I like your thought, but isn't the Moebius 1/72 scale??
B^)
wlambing
Postby Casey Thrower » Sat Oct 06, 2012 10:30 am
wlambing wrote:Casey,
B^)
You are correct. I had 1/48 on my mind I guess.
Casey Thrower
