Postby Racer » Sat Jun 30, 2012 8:56 pm
Another neat thing is that because of the size of this beast, I can actually CNC mill out the brass
parts directly instead of going the photo-etch route.
Now maybe as I move forward up the hull, the metal parts may get more complicated but I do have
a 1/32" end mill which can really do fine milling.
We shall see.
Here is a shot of the brass parts for the section I am working on currently.
This is a 2"x2" piece of 0.010 brass sheet milled with the 1/16th end mill.
Tom Mihelich
Racer
Postby Racer » Sun Jul 01, 2012 1:40 pm
I made some really nice progress today on the Grayling.
The cutting of the thin brass with the CNC went perfect!
They cut out super clean and fit great into the hull depressions.
I also threaded the prop shaft for the M6 prop and locked that baby down with some red Locktite.
Don't want that guy flying off that is for sure.
All that is left now is to paint the brass pieces black and add the zinc's. This would then be followed up with a flat clear coat to protect the paint.
Here are some shots of the finished product.
I am feeling pretty good this afternoon as you might imagine.
Top 3/4 Pic (There is a manhole hatch behind the top Rudder)
Bottom 3/4 Pic
Tom Mihelich
Racer
Postby Racer » Sun Jul 01, 2012 8:53 pm
I was about ready to make my zinc anodes when I came across this diagram.
How cool is this!
Tom Mihelich
Racer
Postby Racer » Mon Jul 02, 2012 6:58 pm
Added the decals this evening and CNC'd the zinc anodes out of styrene.
I sure am glad I found that drawing of the zinc's.
Almost done....
Tom Mihelich
Racer
Postby Racer » Tue Jul 03, 2012 12:06 pm
With the flat clear coat having been put on for protection, the Propulsion Module section of the build is now totally completed. 8)
I just hope the rest of it comes out as nice as this part of the build did.
Now, on to the next section of the build.
Tom Mihelich
Racer
Postby Racer » Sun Jul 08, 2012 9:15 pm
Tonight I made huge progress on the next section of the boat.
I have the exterior details worked out as well as the WTC which will house the motor
and the servos for the tail surfaces.
Tom Mihelich
Racer
Postby Racer » Tue Jul 10, 2012 7:49 pm
Here I have added the two waterproof connectors which will transfer the power to the servos, motor and the
rear Upper Rudder Stern Light. This will keep the WTC looking clean and modular.
Tom Mihelich
Racer
Postby Racer » Sun Jul 22, 2012 3:01 pm
The boys have been hard at work in the fabrication shop and have completed
the three main bulkheads contained within the Control Module.
Tom Mihelich
Racer
Postby Racer » Thu Jul 26, 2012 9:09 pm
I thought I would take some time and work out the detail photo-etching for the
Propulsion and Control Modules.
I was able to sift though the many photos of this class of submarine on the net and I think
I have captured these details fairly well.
I was only able to find the one photo of the MSW suction and discharge details and
took a shot at them here.
I have been corresponding with Jeff who has done a fine job on a set of Nuke Sub photo-etch details in 1/96th and
he was going to look at seeing what kind of details could be had blowing them up to 1/48th scale.
The MicroMart Photo-Etch Kit should be on the door step Friday. :)
Tom Mihelich
Racer
Postby PaulC » Thu Jul 26, 2012 11:14 pm
Tom, please post the MSW image if you can. I've seen drawings but never a pic.
Postby Racer » Mon Jul 30, 2012 6:54 pm
Here is a shot of the propulsion module details.
Photo etching?? No.... CNC. :D
I pushed the machine to the max with this one for sure.
Using a 1/32 end mill I was able to create all of the outlines.
I also needed to duplicate 1" and 1/2" size holes in 1/48th scale which meant getting out the pin vise
and micro drills.
I think we all know how easy it is to snap a #80 drill bit.
I decided to give it a try in the CNC machine.
:idea: How to chuck up a hair size bit??? Just chuck up the pin vise itself. :D
I actually was able to peck drill at .001 depth levels till it went through the metal without breaking the bit.
I guess I was a little premature getting that Photo-Etch kit.
Tom Mihelich
Racer
Postby the dark knight » Tue Jul 31, 2012 4:22 pm
wow! That is a very sharp build! Keep up the good work!
Jon Jones
the dark knight
Postby Racer » Wed Aug 01, 2012 10:21 pm
Here is my 2nd cut at the aft flood grates with careful guidance from my Jedi Master Wlambing. 8)
This should cut very well with the 1/32 End Mill in the ABS sheet stock.
Tom Mihelich
Racer
Postby Racer » Sat Aug 04, 2012 3:02 pm
I finished the first grate this morning and it came out great. (or is that grate...something like that)
It has every bit of detail that the 3D model has.
On to the second one.
Tom Mihelich
Racer
Postby Chuck Chesney » Sun Aug 05, 2012 10:20 am
I've been watching your build....Great job! It's very professional, and should yield a first class sub. I have a question regarding the watertight electrical connectors. What brand are they, and where did you get them? Are they truly waterproof, or just water resistant? They look (from the photos) like the sort of thing that almost all sub guys could find a use for.
Thanks, and keep up the really good work !
Chuck
Chuck Chesney
Users browsing this forum: Ober Freak
