MODELING THE USS WILL ROGERS
Re: MODELING THE USS WILL ROGERS
Postby Bill Rogers » Sat Sep 18, 2010 12:39 am
Thanks for the catch on the zincs. If you can get me the right dimensions it's an easy fix.
Bill Rogers
Postby Bill Rogers » Sun Sep 26, 2010 3:31 pm
For draft marks and hull number I use Gothic style dry transfer decals by Woodland Scenics from my local hobby shop. Unfortunately my local hobby shop closed about 3 years ago so these decals are very old. Fortunately they still worked just fine.
One issue I had before starting was what size numbers to use for the draft marks. Full size draft numbers are 6” high with 6” spacing between the numbers. At a scale of 1:120 the closest I could come to scale was transfers that were 1/16” high. And this would require spacing less than 1/16” between them. Oh well, it sure beats trying to paint them by hand.
The next step was to layout in pencil on blue tape marks for the bottom of the lowest number and the top of the highest number. The tape also served as a guide to align the numbers vertically. Then to keep from leaving marks on the hull I laid down paper towels where my hands would rest.
Once the number strip was aligned I rubbed a pencil over the decal and the number was transferred to the hull.
For the hull number on the sail I used ¼” transfers that would be 30” high in full scale.
I used blue tape again for horizontal alignment on the sail. Because the sail is small I also used a piece tape to hold one end of the decal strip in place before rubbing it with a pencil. Note how I had to cut off a small strip of transfers to fit the sail. I first transferred the 9 followed by the 5 and finally the 6 to avoid touching previously laid numbers. I reversed the sequence on the other side of the sail. Until the decals dry and are sprayed with a clear coat it is easy to smudge them.
Here are shots of the hull number and forward draft marks and the after draft marks with a coat of clear coat for protection.
The draft marks on the rudder were laid out the same way.
Recall that earlier Boss Subfixer noted my zincs looked too large for this scale. He referred back to the picture of the Daniel Boone in an earlier post to show my error. Good catch! Anyhow, I did some research on zinc anodes and I’m making new ones closer to scale. The ones you see in this picture have already come off and I’m getting ready for another airbrushing to touch up the paint in that area.
Once that’s finished I’ll do another coat of clear coat and get on to installing the masts.
“Will” Rogers
SSBN659
Bill Rogers
Postby Bill Rogers » Tue Oct 05, 2010 9:26 pm
When I started construction of this model in April 2009 I knew it would take over a year to complete it. So I took hundreds of pictures along the way to document what I did in case I wanted to do another model. I’m not sure what that model will be but this one is now finished except for the display case that is being fabricated as I write this.
For those who have not read the entire thread or who may not remember what it looked like at the start, here is what the beginning looked like.
It’s been a long haul, but here is USS Will Rogers (SSBN-659) as she is today in my office at home waiting for the display case. The base is a piece of ¾ inch birch with poplar panel molding side rails and stained in cherry. The supports are 5/8 inch clear acrylic rods.
I’ve also included a shot of the bottom showing the main ballast tank flood holes, missile tube compensating system ball-valve openings, main condenser seawater intakes and discharges, auxiliary seawater intakes and discharges, secondary propulsion motor, and a host of other hull openings including the trash disposal unit discharge.
Recall in my previous post I had been informed that my zinc anodes were too large for 1:120 scale. With some research I came up with an anode size of about 8 feet long by 6 inches wide and made the corrections. Cutting off the original anodes meant re-sanding and painting around the rudder. The work also required redoing the rudder draft marks. Since the prop had already been installed and the bottom hull painted I masked as shown below to protect around the work for painting.
Once that work was finished, I installed the masts. Each one was hand made using a variety of different materials and hand painted as shown. I don’t know how often, if ever, all the masts I’ve modeled would have been deployed at the same time. I used a picture of USS Will Rogers departing Holy Loch as my guide for the masts but it didn’t show the snorkel intake/exhaust nor the surface search radar deployed. I added them for effect.
The next three photos show the details on the main deck and sail working forward from the propeller to the bow.
The display would not be complete without the “builder’s plaque” so I’m having one laser engraved in black background with gold lettering at a local trophy shop.
It will look like this, centered of course:
Benjamin Franklin Class Ballistic Missile Submarine
“Last of the Forty-One for Freedom”
Built by Electric Boat Division of General Dynamics Corp., Groton, CT
Laid down 20 Mar 1965 Launched 21 Jul 1966
Commissioned 1 Apr 1967 Decommissioned 12 Apr 1993
Model by William C. Rogers, Sr. Scale 1:120
At this point I thank, again, all of you who offered help in the way of information, tips and suggestions in completing this project.
FWE
“Will” Rogers
SSBN659
Bill Rogers
Postby greenman407 » Wed Oct 06, 2010 9:36 am
Its easy to see that this model is MUSEUM QUALITY! Thanks for sharing it with us. When are you going to start on the next one? :D
Postby Boss subfixer » Wed Oct 06, 2010 12:12 pm
Will,
With all the hard work you put into this beauty, have you considered putting a mirror underneath the boat to show off your handy work on the bottom? I've seen it done before and it's kind of cool to be able to see the lower detail. I too look forward to your next project.
Don Evans
SCM# 2733
Boss subfixer
Postby Bill Rogers » Wed Oct 06, 2010 2:25 pm
Well thanks very much guys, I appreciate your comments.
About the mirror, yes, great idea. I did that on my Blueback display model several years ago. On that model I was fortunate enough to have photographed the entire bottom while she was on dock in Portland, OR. The model also has the TDU (Trash Disposal unit) overboard. The mirror has to be angled about 15 to 20 degrees to get the best perspective of the bottom.
As to the next project, I'm not sure. Any suggestions?
"Will" Rogers
SSBN659
Bill Rogers
Users browsing this forum: Ober Freak
