WTC Materials/Plugs
Postby Crazy Ivan » Sun Oct 25, 2009 12:33 am
Try Mc Master Carr:
http://www.mcmaster.com/#plastics/=47hk8b
Part Number: 8585K22
$19.52 per Ft.
Material Polycarbonate
Polycarbonate Material Polycarbonate
Backing Plain Back
Finish Smooth
Shape Tubes
Tube Type Round
Length Cut-to-Length
Available Lengths Sold in 1' increments
Maximum Continuous Length 8'
Inside Diameter 3-3/4"
Inside Diameter Tolerance ±.040"
Outside Diameter 4"
Outside Diameter Tolerance ±.040"
Clear Clear with No Tint
Operating Temperature Range -40° to +200° F
Softening Point +290° to +315° F
Performance Characteristic High Impact Strength, Weather Resistant, Wash-Down Applications
Tensile Strength Good
Impact Strength Excellent
Tolerance Standard
Hardness Rockwell R118-R126
Specifications Met Food and Drug Administration (FDA) Compliant, Underwriters Laboratories (UL)
UL Rating UL 94HB
Crazy Ivan
Postby JWLaRue » Sun Oct 25, 2009 2:14 pm
For the amount of material that is typically used to build a dive module, it doesn't make sense to not use the best that is available. I have always gotten excellent product fromMcMaster-Carr.
Why does it matter if McMaster-Carr doesn't have a location near you? Their shipping times are always very good and very predictable.
