Simon Lake - The protector
Postby hampboats » Thu Mar 05, 2009 10:01 pm
This is the beginning of my first building thread, the Simon Lake sub the Protector.
SIMON LAKE is credited with the development of the basic submarine technologies which are essential for safe and successful operation of the submarine; such as, even-keel hydroplanes, ballast tanks, divers' compartment, periscope, twin-hull design, and much more. No modern submarine could operate today without using the advancements made by Simon Lake, and which were adopted worldwide by the early 1900's. He achieved over 200 patents in his lifetime.
SIMON LAKE was originally referred to as a "Pioneer Submarine Inventor". Today, Simon Lake is regarded as ...The Father Of The Modern Submarine.
Except from the Simon Lake Website
I am building the boat in 1/24 scale. The original boats was 67 feet long and 15 feet wide. It had three torpedo tubes, 2 forward and one aft and carried one small rapid fire gun in the turret on the conning tower. The boat was launched in 1902. The version I built was a combination of the artist conception, patent drawings and also the final production boat. It is unique in that it has not only aft dive planes but two set of two planes midship.
This is the hull and conning tower prior to starting the build. Only two of these hulls have been made. The hull walls are very thick which made the boat even without fittings and hardware very heavy.
This guy got must have made someone mad to get this duty
Progressing through the build:
Very well built hull:
Starting to gather the parts:
Making the end caps for the 4" wtc. Had a problem and got a bubble under the mold. It was easy to cut off and file smooth after I made each end cap. I started out having a 4" WTC for the motors and servo and a 3.5' wtc for the ballast tank but I had to change to one 4" because I needed the extra volume to maintain a decent waterline.
First (2) wtc attempt until I changed to one large one:
Wrong motors. The 6v pittmans stalled out. I changed to 24V pittmans at 12V- perfect.
Starting to build the hardware:
The keg has got to go and be replaced by a more realistic one:
Adding the aft dive planes:
95% of all of the soldering was done with a resistance soldering unit. Well worth the money.
Setting up the universal shafts.
Pic a little fuzzy.
Ballast tank
Adding the side dive planes:
Adding the wheels and dive plane protection rails:
The periscope has also been added
Dave Hampton
Indy Admirals
www.indyadmirals.org
hampboats
Postby Scott T » Fri Mar 06, 2009 1:49 pm
Great project. That is a good looking start with the hull moldings.
Can you show pictures of the hull master build and molding process;
time permitting.
-Scott T
Hull Mouldings
Postby hampboats » Fri Mar 06, 2009 2:33 pm
I didn't make the hull. It was made by someone else and I bought it from him. The hull is based on the artist concept of the boat which is the one most peope recognize.
Dave Hampton
Indy Admirals
hampboats
Postby Sub culture » Fri Mar 06, 2009 3:54 pm
Nice to see someone modelling one of Lake's boats.
Sadly he's almost been forgotten about. I especially like his Argonaut I, with the wheels on the bottom- you could go trundling about on the pool bottom like an underwater buggy.
Postby tsenecal » Fri Mar 06, 2009 8:26 pm
dave,
two questions:
1) what is the volume of the ballast tank, it looks even stubbier than the 500ml engel i have in my alvin
2) what kind of high tech gadget are you using for the ballast tank controller? :)
tim
tsenecal
Protector
Postby hampboats » Fri Mar 06, 2009 11:16 pm
It is the 500ml tank. Only electronics I currently have on it is a channel to actuate the tank fill and empty switch with a missing pulse detector to blow the tank. I am still in the trimming phase. I only need to fill 1/4 of the tank for the boat to submerge. Tim, are you using the Engel switch or are you just doing the same as I am?
Dave Hampton
Indy Admirals
hampboats
Progress
Postby hampboats » Fri Mar 06, 2009 11:35 pm
Torpedo door build:
Deck Hatch: these are large wheel hubs for airplanes:
Conning tower
WTC and a good view of the side dive planes. The gray wire is the cable coming from the waterproof servo to the WTC.
Dave Hampton
Indy Admirals
hampboats
Postby Warpatroller » Sat Mar 07, 2009 1:30 am
Dave,
What material did you use to make your end cap masters from?
Where did you purchase the many brass strips (in your one photo) from?
Warpatroller
Postby tsenecal » Sat Mar 07, 2009 4:24 pm
dave,
I am using the
Ballast Tank Switch BTS2 6V
http://www.engel-modellbau.de/catalog/p ... 6c77219ea3
in all three of my subs:
500ml & BTS2 6volt in the Alvin
500ml & BTS2 6volt in the self made 1:32 Type II
750ml & BTS2 6volt in the now retired Robbe type VII
I have only had problems with the ones that have gotten wet :)
tsenecal
ballast control
Postby hampboats » Sat Mar 07, 2009 8:28 pm
Aside from the fail safe feature, does this unit allow you to preset how much you want the tank to fill and empty. i.e. only half full or completely empty. Is that what they mean by autotrim?
Dave Hampton
Indy Admirals
hampboats
End caps and brass
Postby hampboats » Sat Mar 07, 2009 8:34 pm
80% of the brass came from the local ACE Hardware store, I did get some of it at Hobby Town. Hobby Town had more pieces in longer lengths.
The end cap master was made from Delrin. I use RTV to make the mold and cast the end cap out of RP132 Resin Fast Setting filled Polyurethane
Dave Hampton
Indy Admirals
hampboats
Final pictures before painting
Postby hampboats » Sat Mar 07, 2009 8:38 pm
these show the boat before I start the final clean up and sanding prior to painting. I will post more photos of trim test
Dave Hampton
Indy Admirals
hampboats
Trim Testing
Postby hampboats » Sun Mar 08, 2009 6:21 pm
Trim Testing in the expensive model sub test tank. It was time for spring cleaning the Spa any how. It does help if you turn off the jets.
Dave Hampton
Indy Admirals
hampboats
Postby tsenecal » Sun Mar 08, 2009 6:33 pm
dave, the autotrim function is actually part of the ballast tank itself. autotrim tanks have 3 limiter switches. one for empty, one for "neutral" ballast and one for full ballast.
autostop tanks have a set of two limiter switches, empty and full.
the BTS2 is designed to work with either the autostop or the autotrim.
tsenecal
Postby hakkikt » Wed Mar 11, 2009 3:38 am
Very cool subject, should look great in the water with its deck so close to the waterline. Can't wait to see the first pictures in the water!
- mobilis in mobili -
SC#1604
hakkikt
