Steve Neill builds a Big Dave Seaview
Postby junglelord » Wed Feb 25, 2009 4:42 pm
Steve, do you power your lights from the rx?
Or do you power them external of the WTC?
I was looking at RC LEDs that plug into the rx.
Not sure that is the proper way to go with a Sub-Driver or WTC.
What did you do?
Dean
junglelord
Postby U812 » Wed Feb 25, 2009 4:51 pm
Dean they are external. Simple!
U812
Postby junglelord » Wed Feb 25, 2009 5:10 pm
Thanks.
Do you use a 9 volt?
Last question....LOL.
:lol:
junglelord
Postby U812 » Wed Feb 25, 2009 5:22 pm
3 volts. The LEDs are 3 volts.
U812
Postby Sub culture » Thu Feb 26, 2009 4:42 am
LED's are a piece of cake to work out, you only need to understand basic electrical units and a little bit of Ohms law.
This link is a little online calculator which speeds things up a lot.
http://led.linear1.org/1led.wiz
Postby junglelord » Thu Feb 26, 2009 9:45 am
HAHAHA.
Your going to laugh, but I am a electronic technologist who worked 5 years with Military Sonar.
8)
I know all about electronics, I however am learning about model subs.
:D
I could run a system that runs direct from the rx for my SeaWolf.
I would run a system external in the SeaView.
You could say I know what I want, I just wanted to know how most are setting up their work....and I must say I am getting the confidence in the other areas I was weak in......CUTTING PLASTIC.
Now I am like a surgeon, and that drill press I now have....I am READY TO BUILD.
8)
junglelord
Postby Sub culture » Fri Feb 27, 2009 4:40 am
Maxim IC do some really nice little LED driver chips. They tend to use switchmode technology, so they're very efficient.
However if you're driving just a few LED's then you can use linear regulation and/or resistors to limit the current.
Postby Lobo » Sat Feb 28, 2009 11:42 am
I've got a Moebius Seaview I plan to start in the fall of 09, but for now I am tweaking my SN 1:144 GW for this upcoming season.
I picked up a few LED lighting kits & switches, but I just came across this NERS switch from Chris Hansen. Chris is a great vendor. He was at this years WRAM Show, I enjoyed speaking to him. I did not know he had this switch until a week after the show...sigh! I ordered 2, one for my SN GW & one for my Seaview. (I am lighting my GW).
Since I have a 5 channel NOVAK receiver in my SN GW, (BD RCABS Kit)leaving a channel left over , I am going to use it for Rx LED lighting control. Why not go Rx for lights if you have a channel available? The NERS switch is only 18.00 & shipping is reasonable! Seems a waste not to do it!
Attached is the link for for the NERS link from Hansen Hobbies. Click on the instruction page included on the product description webpage!
http://www.hansenhobbies.com/products/onboardacc/ners/
Lobo
Postby junglelord » Mon Mar 09, 2009 2:23 pm
Hi Steve.
:D
I wish I could commission you to build me a Moebius Seaview...but being on a pension thats not possible...however I would like to ask you about foam and ballast in a Big Dave WTC build. I see the steel rods and the brass sleeves, very cool. I see very little foam. Did you use much?
Or is that a result of the WTC vs the Merriman build?
Thanks.
junglelord
Postby U812 » Tue Mar 10, 2009 1:43 pm
Just white dapron sheet foam you buy from the LHS used to make RC airplanes. It's the same stuff foam plates are made from.
I forget what it's called but it's several thin layers built up inside the hull between the bulkheads.
Hope that helps,
U812
Postby Bigdave » Tue Mar 10, 2009 2:58 pm
Cellfoam-88 by Midwest you DuMMy!! :oops: :lol: :lol: :lol:
I will let it slide this time Mr Neill. :shock: :lol: :lol: .
BTW- Our snow finally melted. WOOPEEEE!!!!BD. (BID DUMMY)
Postby U812 » Tue Mar 10, 2009 3:33 pm
Well it's about time Mr. BD! Get busy! Build things. Go forth and multiply them!
And hey! I was building model RC airplanes with that stuff before it was every called that or had it in the LHS! Ha!
U812
Postby junglelord » Tue Mar 10, 2009 4:49 pm
Bigdave wrote:Cellfoam-88 by Midwest you DuMMy!! :oops: :lol: :lol: :lol:
http://www.midwestproducts.com/item_det ... tem_id=429
By the looks of it, one sheet will do one Seaview.
Correct?
Thanks guys.
I still got snow and lots of ice to melt...
so how about that Seaview unit Dave....
MMMM?
:D
junglelord
Postby U812 » Tue Mar 10, 2009 5:40 pm
Correct it will and then some. You get two in the bag anyway.
U812
Postby Bigdave » Tue Mar 10, 2009 6:08 pm
You can see it comes in different thickness. Nice stuff to work with. BD.
