1/32nd OTW Designs S Class build thread
Postby dhffr » Mon Jun 16, 2008 9:32 pm
Thank you.
I plan on using a custom propel/blower setup for the S class. The ballast tank is custom built for the S class hull. (It goes the full beam of the hull and is only 3 inches thick with a flat top) I am going for maximum waterline stability.
Darrin
dhffr
Postby TMSmalley » Mon Jun 16, 2008 10:02 pm
Go for it!
Postby dhffr » Wed Sep 24, 2008 11:04 am
Finally, some progress to post. I am starting to get the ballast system worked out. Many thanks to BIGDAVE for the help. Now, I can finish up details that were on hold. Stern linkages are finished. Used some CF rod to keep them stiff without any supports. The internal linkages are all rotary output with an additional support bushing about 1" away from the BHS. This keeps everything from getting loose and sloppy. Another photo shows a micro swith and linkage to shut the radio down while in the water. With my big boats, I like to leave them in the lake using a mooring anchor. Last photo shows the battery wtc. It will hold a custom built 10 cell 4600nimh pack and sits at the bottom of the keel with a bit of room for sheet lead below. Ballast system details are next. Looks like it will be a traditional RCABS setup. More to follow.
DH
dhffr
Postby dhffr » Wed Jan 28, 2009 11:52 am
Been a while since the posting. Wanted to post photos of the initial paint and weathering.
dhffr
Postby dhffr » Mon Feb 02, 2009 3:28 pm
Final ballasting is done. Next set of photos will be from the lake.
DH
dhffr
Postby raalst » Mon Feb 02, 2009 5:31 pm
OK ! congrats !
looking forward to those "in action" pictures.
Postby dhffr » Mon Feb 09, 2009 2:40 pm
Its in the water! Sea trials went really well. Still had it trimmed a bit light to be safe. Get about 5 full Propel blows and unlimited with the snort pump. One thing I noticed. My BE-VR got pretty hot. Is this normal? I dont remember it getting beyond warm with other models.
Darrin
dhffr
Postby Sub culture » Mon Feb 09, 2009 3:23 pm
Depends on how much current you have going through it, and also how much voltage it's dropping down from. The higher the voltage, the less current the regulator can deliver and the more power it has to dissipate in heat.
Exceptions to this are switch mode BEC's which are more efficient and work with a wider range of voltages without losing current capacity as the voltage rises.
I don't have one of the BEC's you're talking about, so I don't know what regulator they use in them, but would hazard a guess that it's something along the lines of a LM2940, and they should be able to handle 1A of current, although this may decrease a bit if you're running a 12 volt system.
Postby U812 » Mon Feb 09, 2009 6:22 pm
Excellent work Darrin. Simply the best I've seen yet here.
U812
Postby dhffr » Tue Feb 10, 2009 3:32 pm
Thanks Steve.
A couple shots to add. Love the sepia look.
Darrin
dhffr
Postby U812 » Tue Feb 10, 2009 3:41 pm
Looks like the real thing!
U812
Postby Pirate » Wed Feb 11, 2009 1:18 am
Your weathering job on the rust is fantastic, Darrin.
Postby dhffr » Tue Feb 17, 2009 12:20 pm
Second run also went without a hitch. Got the final rigging and details on for a surface run photo. Hope to run it at my club meeting on Sunday.
DH
dhffr
Postby junglelord » Tue Feb 17, 2009 12:33 pm
Nice stuff.
I envey those who have year round running weather...
meanwhile I am awaiting breakup of the St. Lawrence River
:roll:
junglelord
Postby Myles Yancey » Tue Feb 17, 2009 7:31 pm
Great work, nice job
Myles Yancey
