Trumpter Seawolf
Postby Wayne Frey » Tue Jan 27, 2009 7:22 am
It will be the next logical step the Russians should take in evolution of their boats.
While I like the little Alfa, it's day has passed.This will be a 21st century , worry-about-it out-there somewhere , boat.
Postby redboat219 » Tue Jan 27, 2009 10:41 am
subcaptian wrote:maybe an Alfa, it is the fastest sub in the world, given to that stupid liquid magnesium reactor.
Subcaptian,
AFAIK Alfas used Lead-Bismuth Alloy Cooled Fast Reactors not Magnesium.
redboat
redboat219
Postby Rogue Sub » Tue Jan 27, 2009 6:59 pm
Magnesium reactors would make an awesome last start up! :)
Postby redboat219 » Tue Jan 27, 2009 11:13 pm
makes one helluva flare :D enough to reduce the sub to a molten puddle of slag!
redboat219
Postby Wayne Frey » Sun Feb 01, 2009 12:09 pm
Looks like this will go to a supplemental thread on repairs.
I tried to reassemble the pump jet shroud base. After getting it close, I realized it was just not going to be the same no matter how I willed it.
The answer is clear. I reordered another pumpjet to replace the damaged one.
I used the dremel to remove the base, and filed the stern back for the new shroud. I also discovered the front lower lip was cracked, so I removed that also. Found a crack in the lower part of the hull to be repaired. This is turning into a deal!!!
Screw shown to show paint gone where it was bent badly before.
Postby Rogue Sub » Sun Feb 01, 2009 12:50 pm
What is that last shot wayne... a look how many pump jets I have that dont fit my seawolf picture?
Postby Wayne Frey » Sun Feb 01, 2009 6:46 pm
For scale, and yes, to see who is paying attention.
This all comes into play as my path is now clear for the next two years. But, the subject at hand is not neglected.
Postby Rogue Sub » Sun Feb 01, 2009 7:08 pm
So, why dont you just go ahead and spill the beans! I know your doing the Akula which will be fun because I got another one so I can redo it better this time. The other projects your hiding is to diff to determine. The reason for about 4 large PJs though is boggling.
Postby Wayne Frey » Sun Mar 08, 2009 8:55 pm
What the heck is Wayne been doing????
Hanging out in the Heart Hospital of Houston(4 times in 90 days). But, I am still here, darn it!! Ha!! There are a few outside things going on that have slowed me down also. But, fans, while we waited, the screw got straighten,trued,resanded, and repainted.
The old pump jet base was gradually cut away, and resanded the stern down to pre-install condition.
I then slid the ouput shaft through the bearing in the hull, to insure alingment, and free turning (especially since the bearing is already fixed).
Using the bearing as a guide, I CAed the new pumpjet on.
I did, of course, clean up the inside of the new pump jet with files, and evercoated any irregularities and smoothed out. Why? For lower acoustical signature, of course!!!
Postby Wayne Frey » Mon Mar 30, 2009 10:03 pm
Done.
Patrol ready.
That will do pig, that will do...
Postby Pirate » Wed Apr 01, 2009 12:06 pm
Wayne,
I may be mistaken in what I'm seeing in these pictures, but I'd appreciate it if you didn't put my pumpjet assembly on someone else's Seawolf kit.
Pete
Postby redboat219 » Wed Apr 01, 2009 12:42 pm
I don't think Wayne's using your PJs. The one he has on looks appropriate for 1/144 and not 1/96 scale. I think he's just using it for comparison...
redboat219
Postby Wayne Frey » Wed Apr 01, 2009 6:17 pm
Pete,
That is the Trumpetor Seawolf in 144. It is a Caswell Pumpjet. Which, for that model is the best to have. It looks very scale.
The pumpjets I got from you are going on the classified projects I told you about :) You already know where the 3 are going,remember? (and you are sworn to secrecy).
I actually consider that a compliment, Pete. Your Seawolf in 1/96 is the best current production avalible in that scale. For my little park runner 1/44 to pass as accurate enough to even momentarily make you think it might be yours tells me it must look ok :) I am pleased with the project:)
While my build went with the reverse RCAB, which intrigues the heck out of me, Caswell's fittings kit to upgrade/enhance the Trumpetor kit are excellent quality. Credit given where due.
Now that this one is done, I have something to run with the Subron 5 guys while I have the REAL project again , working in drydock.
Postby xxl » Fri May 15, 2009 9:43 pm
looks like a great boat hope you enjoy it mine kinda went south i think i got in over my head
Stihl 026 066
Engel lafayette
xxl
Postby kazzer » Sat May 16, 2009 8:07 pm
Wayne Frey wrote:Pete,
Not mine, I only sell them. Merriman (D&E Miniatures) is the designer/manufacturer.
kazzer
Users browsing this forum: Google [Bot], RBR687
