OTW Type XXIII questions
Postby Delphin » Wed Feb 14, 2007 8:45 pm
I came across a lower section for a OTW Type XXIII and need a little help. I am going to try to lay up the upper hull and sail. What is the measurement from where the upper and lower hull splits to the top of the hull?
What are the measurement for the to the top of the sail and the sail length?
I think the lower section I found is 1/24th scale.
Thanks in advance.
Delphin
Re: OTW Type XXIII questions
Postby sam reichart » Wed Feb 14, 2007 9:52 pm
Delphin wrote:I came across a lower section for a OTW Type XXIII and need a little help. I am going to try to lay up the upper hull and sail. What is the measurement from where the upper and lower hull splits to the top of the hull?
Thanks in advance.
you have a heck of a task ahead of you.
before you begin that, why don't you check with Bob Dimmack (otwdes@msn.com) and see if he can cast you up an upper hull, or if he has a "second" that you could buy and then cleanup...
If you insist on doing it yourself, I'll pull some measurements for you.
let me know...
Sam
sam reichart
Postby Delphin » Thu Feb 15, 2007 8:01 pm
Sam,
Thanks for the reply. Can you pull some measurements for me?
Thanks.
Delphin
Postby sam reichart » Fri Feb 16, 2007 9:49 am
It may be a few days...got a busy weekend coming up.
sam reichart
