CB italian midget sub : lining up the hull halves
Postby raalst » Sat Mar 10, 2007 5:32 pm
yeah,
the advantage of an obscure subject : nobody knows where
you goofed !
I measured the zagreb boat, up-diddled my ANB drawings and will
build it like it stands in Zagreb.
warts, buoys & all.
now to find a few consecutive hours just to get going again
on the model...
Postby raalst » Wed Mar 28, 2007 3:12 pm
the photo's look good, but I'm not done sanding yet, I'm afraid.
front
back
Postby raalst » Wed Apr 11, 2007 1:17 pm
I rebuilt the superstructure (it is level, *not* sloped
as the drawings suggest).
I build a new and smaller periscope housing, different from the drawings too.
and a toy-tank-hatch made a perfect sub hatch.
made a mold of plaster, put in a bit of grease, and
filled it with polyester filler. presto : two hatches.
and the sanding of the hull continues of course...
Postby gantu » Wed Apr 11, 2007 2:37 pm
Very nice build :D
Gantu
gantu
Postby raalst » Sun Apr 15, 2007 4:36 pm
to take a leave from sanding,
I formed the "windabweiser" from
a bit of aluminium plating.
after lots of hammering, it begins to look like
the real thing. getting the curve right is
tricky.
Postby geo_sim » Mon Apr 16, 2007 4:21 pm
Great job raalst!
Post more pictures!!!
Best regards
George
geo_sim
Postby raalst » Mon Apr 16, 2007 4:46 pm
Thanks, George.
today's work was learning how to scribe and how
to copy the hole pattern on the periscope
housing. it went fairly well, except one hole in the
middle. I'll try that one again.
Postby raalst » Wed Apr 25, 2007 4:52 pm
current progress on the tower :
just like this
it is hard to recreate those hole patterns with some
regularity.
I'm not 100% satisfied, but it will do.
Postby Sub culture » Thu Apr 26, 2007 6:41 am
Have you thought about photoetching the holes?
Postby raalst » Thu Apr 26, 2007 3:41 pm
andy,
yep I did, but that does not mean I have the
equipment or materials for that.
But I seem to recall that somebody mentioned
he did have such stuff, hmmmm.
I'll have to re-make it anyway, because it is clearly
too high now, compared to the original.
Postby Sub culture » Fri Apr 27, 2007 5:25 am
You only need a plastic or ceramic tray and some ferric chloride to photoetch.
If you have access to a laser printer you can make a one of a kind etch resist stencil using 'paintbrush' on your computer, and iron it onto the aluminium using a household iron set to 'cotton'.
Postby raalst » Sun Apr 29, 2007 11:40 am
I found another solution.
I had an old circuit board lying around.
a diagonal slice of it gives me a row of
alternating 3 and 2 hole columns.
This strip can then be used as a guide for the drill.
behold the power of the jig !
I'm happy...
Postby raalst » Wed May 09, 2007 4:44 pm
I tried my luck with the hatches, came out not too bad, but needs a bit more work still.
Postby U812 » Thu May 10, 2007 8:46 pm
Very nice work!
steve
U812
Postby gantu » Fri May 11, 2007 3:44 am
Hi raalst
looks perfect for me nice work
Gantu
gantu
