SF Harpoon Scratch Build
Postby elec_tech » Sun Jun 04, 2006 12:53 am
Update:
Fun day today, spent the morning running around picking up supplies and doing things with the wife which left the afternoon for subs. I picked up some black hi-build primer and a hand miter saw and block. the miter block should help me out a lot with cutting my WTCs and balsa blocks etc... more tools for me.. WOO HOO!! I also tried to find the Icing both KevinMc and Steve(U812) are using and I couldn't. I Tried a few autobody shops and a few auto supply stores and I couldn't find it. maybe if someone could tell me what it is or show me a close up picture of the bottle so I could read it then maybe I could find an alternate.... maybe....
Anyway, onto what I did today. This afternoon I laid a couple coats of primer on the main hull in preparation for the rest of the build. Looks great, all black, its sleek and fast... I'm gonna love this thing!
I also started work on the deck. First I started by laying down a strip of chart tape down the middle of the hull. This gave me a base line to work with in aligning the two pieces with the hull. I want as few alignment issues as possible!! it took me a few tries but after a while I was satisfied and moved on.
I then glued the balsa pieces I had cut previously onto the hull and secured them. It didn't take long and required little sanding. since I had already cut the main curvature of the hull on the pieces, they aligned themselves pretty easily and with the chart tape giving me the center points, I think everything lined up quite nicely.
Following the glue stage, of which I ruined the primer job.... some glue ran down the hull and I now have to repaint a small section.. arrggg.... Anyway.. following the glue stage I started sanding down the flat sections and corners to get my desired shape. Again, with it being my own design I can let it take whatever shape I desire... nice huh?
So that's where I'm at as of this evening. Here are the pictures....
Progress continues......
elec_tech
Postby elec_tech » Sun Jun 04, 2006 11:35 pm
Update:
Had a few more hours to work today so I cut out the next little bit of the deck... should be the last piece for the deck. So I'm going to pick up some thin glass cloth when I can and secure it down, make it solid and then start detailing it.
I also spent some time adding reference lines to the sides of the hull so I could start lining up the appendages as well as spent some time cutting out the preliminary shapes for the front planes.
Nothing much else done today... that nose took most of my afternoon, cutting, sanding etc.. needless to say I enjoyed myself.
Pictures follow...
Progress Continues.....
Edited By elec_tech on 1150648914
elec_tech
Postby KevinMc » Wed Jun 07, 2006 6:30 pm
Hey Dan, looking great!
Sorry I've not posted an Icing photo for you yet- I read your request on Sunday but haven't been able to "get things together" enough to get you a photo.
I've actually found it under two different labels. Here's the original stuff I was using: (Old photo from OSCAR build.)
I'll try to get a shot of the "other brand" tonight. It seems to be the same stuff, same tube, just a different label. I bought both kinds from CarQuest.
KMc Designs
SC #2870
SubComOn
KevinMc
Postby elec_tech » Thu Jun 08, 2006 11:16 am
Thanks Kevin,
I printed off that photo and tried my local Lordco Auto Parts store and all they had was some reinforced purple filler of some kind... I didn't think that was a match. We don't have CarQuest here on the west coast...I looked up their web page and they are stricly the east coast. RATZ!! I'll try some other auto body places around here to see if I can find it otherwise I might try ordering it online. I'll have to wait for delivery but if it's as good as you say it is... it'll be worth the wait I'm sure.
Thanks Kevin, I appreciate your help!
Dan
elec_tech
Postby elec_tech » Sat Jun 17, 2006 11:31 pm
Update:
First off... I found Icing!!! UAP/NAPA carries it and they have a store 2 blocks from my house... WOO HOO! So I have some now and I look forward to seeing what all the hype is about.
So I spent a couple hours today working on getting a few more of the details mounted on the hull. I also laid down two layers of 3/4 oz. glass on the deck and the little bits I added. I masked off the deck while I glassed but after a couple hours I removed the masking so it didn't cure solid with the glass. To make sure I didn't wreck anything I trimmed all the glass nicely around the edges and pulled off the tape and paper slowly. it all lifted off quite well with little disturbance. I'm letting that cure now and then I'll work on glazing and priming tomorrow if I get a chance. It's getting to a point where I can detail it with weld lines and get the appendages made and scribed into place. Things are moving along quite smoothly I think.
elec_tech
Postby elec_tech » Thu Jun 22, 2006 1:35 am
Update:
OOOEEEE!!!! I love it love it love it!!
Ok.... I've spent the last 2 evenings sanding the fine glass of the deck and details. Also I've been working with the Icing and getting most of the edges true and sharp, filling in some of the cracks, and repairing dents and the like. I also made an effort to clean up the tail section where the prop meets the hull. I think I did an ok job at that as seen in the later pics.
elec_tech
Postby elec_tech » Thu Jun 22, 2006 1:36 am
After I figured I had everything sanded down to my satisfaction level, and before I sanded to much of the icing away making the whole job pointless I laid down a couple heavy coats of high-build primer. I intend to run a light 400 grit sandpaper over it later to flush out some of the surface scratches and unfortunatly some of the paint runs. Getting into the pointy area around the deck proved a little difficult and I oversprayed a little. Here are some pictures of the hull all painted up. OOOOO EEE it's hot!!
This however is my favorite pic of them all... I just like the way the light hit it and how the glare shows off how smooth and consistant the hull is.
Overall I'd say I've been very productive of late and it feels great! I'm really enjoying this build.
elec_tech
Postby Sub culture » Thu Jun 22, 2006 5:41 am
Good work Dan. She's looking like a boat now.
Have you thought about internals?
I'd reckon on a dry hull configuration- think of Big Dave's Sushi.
Tech rack, bayonet ring (or DIY equivalent).
Leaves plenty of room for lots of batteries!
Postby elec_tech » Thu Jun 22, 2006 11:24 am
Yup, I have been starting to think about internals and as nice as Daves Sushi is with a dry hull I think I am going to stick with my original wet hull idea. I've emailed Dave about purchasing one of his Kilo experimenter WTC kits with an RCABS system. We'll see how things go from there.
For the motor and ESC I think that I am going to try and go brushless however I haven't gone so far as to price it out yet. Price is a bit of a factor for me so if it's too much I'll probably go with a standard Speed 540 and either NI-MH or LiPO cells. I have a couple Speed 700BBs but that might be a little overkill!
I have a 4 channel Hitech radio and servos so I'm good there. I'll look at maybe getting an APC and the sub-tech xmix adapter but that should be about it. let me know if I've missed anything.
As for work on finishing the master, I have the sail to do yet, the forward dive planes and the x-tail planes to cut, sand and finish yet. Then I've got a few hours of work yet adding whatever details I wish but molding should be right around the bend.
Thanks for your comments Andy!
Dan
Edited By elec_tech on 1150991583
elec_tech
Postby Scott T » Fri Jun 23, 2006 2:04 pm
Boats looking good.
Your post on making your boats helped motivate me to start mine, though I am a little stalled at the moment. Keep the updates coming it helps everybody.
-Scott
Postby elec_tech » Fri Jun 23, 2006 2:55 pm
Thanks Scott,
Sounds great that you're starting your own build! Make sure you post a build thread so we can see what you're going to bring to the table.
Dan
elec_tech
Postby elec_tech » Sat Jun 24, 2006 11:27 pm
Update:
A great day to build today for sure. The patio above my work area creates just enough shade to prevent it from being a scorcher but is open enough to let you feel the day and it was a nice one indeed. Can't say hot warm it was but it had to be in the mid-20s for sure. That's celcius folks...
I spent the afternoon picking and preening the hull and working on the sail from my little creation. 6 hours I think.... yeah that's about right. I saw a few areas on the hull I wanted to retouch with some sandpaper and paint but nothing really spectacular.
I approached the sail much like I did the deck. I took a piece of balsa block and pasted on the top and side views of the sail. From there I cut out each section and the pieces fell away to give me my very rough sail.
From there I sanded it down to give it it's semi-final shape and moved on to adding one of the main details.... the hatch area. If you look at the first pic you'll see the detail shown on the top view plan. I took out a hole saw, matched it with the plan and presto... instant recessed rough hatch area. Naturally I sanded that down and test fitted the piece on the sub.
Here's where I took a risk, instead of fiberglassing it and waiting untill tomorrow to work on it after the resin cured I tried something different. Knowing that the Icing that I've been working with sets solid in 10-15 min, I mixed up a small batch and rolled the sail in it completely covering it. I let it set and began sanding it back into shape.
Now it wasn't a huge risk as I could've always started over and gone the glassing route but I am pleased to say that the risk payed off big time. I was able to continue working all afternoon because after sanding it back into shape it was a solid as if I had glassed it and smooth as anything.
Following KevinMc's build thread, I masked off the deck area the sail was to be fitted with green painters tape. I couldn't find packing tape and this stuff released just fine so I was ok with using it. I placed the sail where I wanted it to be and mixed up another small batch of Icing. I applied some to the bottom of the sail and squished it on so that the contour of the deck was captured and then using my gloved finger I dabbled a little bit of Icing around the edge of the sail so I could fillet it in.
elec_tech
So... I got hungry, had dinner and then I got back to work for a short while. I cut away most of the excess Icing and sanded the rest down to suit my design. I gave it a quick shot of primer and set it in the sun to bake(it was that nice a day). Now I guess it's fair to mention that I used a combination of 80, 120 and 220 grit paper depending on the area and detail level I was at.
While the paint baked I started cutting out the stern planes but I didn't get very far tonight and I'll talk about them more when I finish them. At the moment they're next on the agenda... that changes as often as my design does!
After I was satisfied with the dry paint, I picked and preened at it a bit and probably will some more later but that's the way it goes. I also positioned it in place and took the jump and scribed it into place, took a few photos and called it a night.
That's about it... more when I get the chance.
elec_tech
Postby elec_tech » Sat Jul 01, 2006 3:53 am
Update:
Got some more time this afternoon & evening and it was pu to good use I think. All together... probably about 7-8 hours of build time. Most of it sanding but what'dya expect? perfection right off the bat? HA!
Ok...I started early this afternoon with the dive planes. I pulled out the pieces that I had cut earlier and began sanding. I tapered the front and back a bit so it would contribute to the overall 'fast' look I am going for. I also curved the edges and tried to make them as identical as possible (not possible but I tried with some success). I then followed the same route I went with on the sail and covered them in Icing.
I spent the next little while sanding them down back to where I had them, only with a thin layer of Icing on them to seal the balsa and smooth them out. Balsa tends to still be a bit grainy, even when sanded down with 220 grit so this cleaned them up nicely. Next was a shot of primer and they are now on the bench for detailing and filleting.
After I worked the dive planes I picked up the piece I cut for the stern planes. I intend to only make one master and cast the four I need for my model from Alumilite. I had cut the basic shape out according to my plans and from there I took my designers discretion and continued to work the piece. I followed exactly the same route as before... sand.. Icing... sand and prime. It is also now on the bench waiting to be detailed.
elec_tech
Postby elec_tech » Sat Jul 01, 2006 3:54 am
Earlier this week I stopped by my new LHS and picked up some small styrene strips/rods as well as the material to make molds (liquid 1 to 1 RTV from PolyTeck) as well as a pack of Alumilte. I'm looking forward to seeing what I can do with all of this great stuff.
Anyway, having these pieces on the bench is nice an' all but I had a hull staring at me all afternoon begging me to start detailing it. I've had ideas floating around my head all week trying to get out so I figured it was about time to let them out.
I started basically just playing with the styrene strips. taking one out and bending it, twisting it and placing on the hull in different spots to see what different ideas would look like. I finally settled on an idea that looks fairly sharp and I went with it. I can't really describe it so here are some photos to speak for me. I secured the styrene rods with thin CA and filled the rear area with the smallest bit of Icing.
Now I'm not sure what it's actually supposed to be but being an SF sub... I'm sure the little SF crew knows what it's for and how to fix it when it breaks :lol:
Moving on... I next tackled an idea that's been trying to get out ever since I saw something similar done by Steve on the Blueback. It's a simple weld line but I felt it adds a lot of character to the design. I pulled out my 1/32 crepe tape and laid out a bit of a weld line pattern on the bow. Trying to get these to match on each side was very difficult and time consuming but I managed to do it and keep it in line with the design. I really like it!
I also took a shot tonight at laying down some flood hole patterns on the bottom of the sub. They're not the best squares in the world...and I did it by eye but I think I'll be able to clean that up when I build the actual model.
Since I don't know when I'll be able to work on it again and I don't want the crepe tape pulling up or any of my vent masks falling off I gave it a quick shot of primer to kindof tack it all down. It also cleans up some of the mess I made with some of the CA and the detail sanding.
That's all I have for tonight...
elec_tech
