SF Harpoon Scratch Build
Postby elec_tech » Sat Apr 01, 2006 2:37 am
So here is the fresh start of my second build. I had an unfortunate accident with my first attempt at it so here goes take #2.
I started again with cutting out the bases for the hull halves with my plans on them. as you know I design my own plans to my imagination so this is something you've never seen before.
Instead of using balsa for the circle halves I decided to use my 3mm PVC foamboard. It's much stiffer and when you see the pictures you'll see why I did it as well. The set of pictures describes the process accuratly enough, within 15-20 min I had all my circles cut and ready for glueing. I am more impressed with the product I put out tonight than my previous attempt. Go figure huh?
Here is where I drew on the center lines and 1/8" offset for each base plank. The circles are 1/8" smaller than the outside of the hull to account for the 1/16" balsa plank and the fiberglass layer and filler that will follow. The discs and bases were also marked as to where the measurment was taken and the disc was to be placed. In total, this had 12 discs of varying sizes.
The Dremel circle cutter tool setup
I drilled a hole OUTSIDE the diameter I wanted to cut so that I could align the blade. This was important as I wanted the blade edge to trace the outside of the compass line, not the center of the blade. I also predrilled a hole in the center so the disc could spin and be cut.
Notice how it's cutting cleanly as I described above.
Finished discs ready for the next step.
These are the two bases being used for the hull halves.
Both halves with mounted discs and ready for planking
This all in about 4 hours work...
Progress Continues...
elec_tech
Postby raalst » Sat Apr 01, 2006 12:59 pm
nice trick to create the disks !
what type of cutter did you put in the dremel ?
Postby elec_tech » Sat Apr 01, 2006 1:53 pm
Ron,
this is the blade that I used, It's a dremel all purpose cutting blade.... here in an excerpt from their website on it.
561 MultiPurpose Cutting Bit
A high-speed cutter with a 1/8" steel shank ideal for cutting wood, plastic, fiberglass, drywall, laminate, aluminum and vinyl siding.
Dan
Edited By elec_tech on 1143914306
elec_tech
Postby raalst » Sat Apr 01, 2006 2:31 pm
thanks.
never seen that before...
I'll have a look in the local hardware store for it.
Might be very handy indeed.
Postby elec_tech » Sun Apr 02, 2006 8:57 pm
Update:
5 hours yesterday and 4 more today proved to be very productive. The planking is down on both halves. The thing looks great!!
So the mesh I was thinking of trying, meh didn't need it. Soaking the balsa, meh, didn't need that either. One day I'll learn to just follow instructions and trust it will work out ok. As for cutting the planks down to 1/4" insetad of 1/2" PURE GENIUS!!!!!! what a save! They wrapped and bent beautifully and I couldn't be happier.
So next steps as per the instructional thread (U812's blueback thread on SP) is balsa filler for the gaps and other things and contour sanding before glass. That's what I intend to do. Use one layer of lightweight cloth and then follow up with bondo glaze and primer. Other than turning the nose that is....
So now to the important things.. pictures... enjoy.
planks followed the curves much better this time around.
Nice and consistant half circles... what I like to see!
The prop fits great!! It'll look smokin!
That's me...
Having fun I am... and this one should turn out to be a show stopper...
Progress continues.....
elec_tech
Postby elec_tech » Mon May 08, 2006 12:12 pm
The Harpoon survived the move better than the Storm so I jumped right back to work on it.
Progress was focused on spreading the balsa filler around. Not really knowing what I was doing kinda stumped me so I gobbed it on and spread it around to try and fill in all the gaps. I'll try and contour sand it next to get it to the glassing stage. I've noticed some flat spots so I'll try to do what I can. I'm not really good at this so I hope I do it right.
Over the weekend I sanded down the first layer of balsa filler and added another after securing the two halves together with zip-ties and a bolt through the front sention (where I still have to shape with foam). I still have to glue it together though. I found that the planking has pulled the halves outward due to the tension of the curves on the planks and so from now on the master will have to continue constructionas a single piece. I really have no choice if I want to keep it all symetrical. I gave it a spin though and very few if any wobbles.
Sorry, no pics of it together yet... later..
Progress Continues....
elec_tech
Postby KevinMc » Mon May 08, 2006 1:44 pm
Hi Dan,
Looks like she's coming along really nicely! If I may offer a tip- when applying filler to a round surface, I would advise using a flexible spreader that can be "bent" to match the contour of the hull. When applying the filler pull it length-wise along the hull (as you have done) but using the curved spreader you should be able to smooth-down the filler in such a way that there are very few "jagged edges" that need to be sanded down.
How were you going to finish this one? (Did you already say and I've just missed it...)
KMc Designs
SC #2870
SubComOn
KevinMc
Postby elec_tech » Mon May 08, 2006 2:18 pm
Thanks Kevin,
I've been trying to use a curved tool but in the move I lost some of my smaller ones so I used the one large one I had. Work with what you got I guess. I'm trying to get better at getting the right tools for the job.
As for finishing the model. I am trying to follow Steves (U812) Blueback thread. All the way from the planking to the fiberglass to the molding. Only now with the plug being in one piece from now on in I might have to follow your thread a little more closely. So getting back on topic, I intend to make a set of molds of it and see if I can take a crack at pulling a hull from them. I might also see about following another route after the mold is made. This is after all just the master.
I have all the time in the world to work on this as I have no deadlines for completion. I was hoping to get a running version for the August regatta in Oregon but I might just bring the master for show. Who know's how far I'll get by then.
Thanks again Kevin,
Dan
elec_tech
Postby KevinMc » Mon May 08, 2006 3:29 pm
Having "all the right tools" is certainly a nice thing but knowing when you don't really need a specialized tool, or how to make what you need is even better. The "spreader" in the photo above is actually ~6 business cards all stacked up. Old credit/bank cards also work but on softer, more tightly curved materials I find the cardboard stack to be much more compliant.
KMc Designs
SC #2870
SubComOn
KevinMc
Postby elec_tech » Sun May 21, 2006 4:06 pm
Update...
Progress at last! and tonnes of it! ok lets start from the start of Fridays work.
First I sanded down the second coat of balsa filler I applied last time, that brought everything to a nice shap and I am am quite proud of it. I know there are a few imperfections and such but I wanted to move forward and I'll deal with them later. I also glued the two halves together with carpenters glue. pinching the nose together I saw a 1/8" gap at the tail due to warping, I mentioned this before but I figured it was worth mentioning again for clarity. So from this point on the model gets built as a single piece.
Next I worked on shaping the nose. I grabbed some of the foam I had left over from shaping the Storm and I 3M 77d it to the vacant nose area. From there it was a matter of sanding it to shape. It didn't come out conical as I had planned... more or less tapered on sides and much more to a point than anticipated. Designs change and I am happy with the result. It almost looks a bit more in touch with the overall effect I was going for.
Another thing I did was insert a couple rods in the nose and tail and mount it on a couple brackets. This brought it up off the table and suspended it so I could check for wobble and work towards fiberglassing. My wife caught me on camera playing with the drill and making it spin. I had to... I couldn't help it. 8)
Seeing as it was still early in the evening, I decided to move up my weekend plans and glass then instead of Saturday. Following regular procedure then I 3M 77'd the glass to the model. I used whatever I had leftover from the Storm which turned out to be 10oz cloth. I see no problems with it and it turned out just fine. After that I trimmed the seams down and made it so all I had to do was lay resin which went fairly smoothly.
I later on laid a nice thick coat of resin glaze over top. The glass was tacky enough for the resin to coat nicely and I think I'll have few issues with bumps and lumps.
Edited By elec_tech on 1148242122
elec_tech
Postby elec_tech » Sun May 21, 2006 4:07 pm
While the glass was tacking up I started working on the deck portion. I bought some balsa blocks a couple days ago just for this. Also, before I moved to Vancouver my father gave me his scroll saw to take with me. I was stunned but he thought nothing of it. That said, cutting out the deck was fairly easily. I laid the plans out on the top and the side of the block. This allowed me to cut the plan view and the side view of the deck out. As the deck curves with the hull it was a litle challenging but I got it and it looks pretty good. It still needs a lot of work but for being just cut out that's to be expected. I also test fitted it on the still tacky hull. I couldn't wait to see what it would look like and I think it will add a lot.
That's it for today but I expect the next few days I will be able to work a bit more. It's a long weekend here in Canada so Monday is going to be nice to have to myself.
Progress Continues.....
elec_tech
Postby mike byers » Mon May 22, 2006 12:24 am
I love your use of shelf brackets!
Brilliant!
De Profundus
Mike Byers
SC# 2486
mike byers
Postby elec_tech » Mon May 22, 2006 9:27 pm
Thanks Mike,
I was quite proud of myself for that one. They we're just sitting in the closet and I thought HEY! YEAH! That would work... and it did...
Not as much progress as hoped for this weekend. I decided to spend the time with the wife instead. Great trade I thought!
Anyway, I managed to get the glass rough sanded and bondo glazed applied. Next step is sanding down the bondo till smooth and priming for spot filling. I'll get to it when I do. I'm taking my time and enjoying it rather than rushing. it feels better that way.
elec_tech
Postby elec_tech » Fri May 26, 2006 11:35 am
Update:
Last night was sanding night, I sanded down the bondo on this one as well as the other. I'm noticing some minor alignment issues with the shape but otherwise things are looking good. just some smallish odd curves that I didn't notice before. I'm trying to even them out with the putty.
I also laid a quick coat of primer so I could start inspecting for areas that need spot fills. It looks nice all one color.
I'm starting to see where I am going to define the "top" of the boat. The nose is helping define that mainly with the way it is shaped but with the overall curve of the hull there is a defined top and bottom. I think it's rather strange that such a definition is taking shape because this was all based on a round hull shape. I don't know if I screwed up somewhere or didn't watch my shaping close enough but since it doesn't look bad I'm just going to forge ahead and see where it goes in the end. I guess the beauty of designing your own boat is you can allow for these types of changes to occur with little effect.
Edited By elec_tech on 1148657858
elec_tech
Postby elec_tech » Fri Jun 02, 2006 11:32 pm
Update:
Over the last couple days it's been a combination of application of Bondo and sanding so there hasn't been much to report..... Untill now. HA!
I've finished the preliminary sanding of the plug and I am going to start working on getting the deck on and detailed. this should take some time but it should be fun. I have noticed some pits ('bout the size of a +/- .7mm pencil lead in dia.) in the Bondo yet but some high-build primer and a quick sand with some high grit sandpaper should do the trick. I also have my detailing to do once the deck and other things are made so I have lots of time to fill those in.
T the important things now.. Pictures.. 8)
elec_tech
