S.M. U-1 - Germanies first military sub from 1906
Re: S.M. U-1 - Germanies first military sub from 1906
Postby DrSchmidt » Fri Jul 04, 2014 5:38 am
Lower hull is painted in RAL7016. Turned out good and the rivets look nice....
DrSchmidt
O.K., I have a few weeks of filling, grinding, applying details and rivets and cleaning behind me, and yesterday we finally could paint the upper hull in RAL7001. Here are the first impressions. I'm rather pleased.
And of course we have to look at the assembly as well........puts a smile on my face :D
DrSchmidt
Postby DrSchmidt » Fri Jul 04, 2014 5:39 am
O.K., spent two weeks with filters and washings to weather the upper hull. I did a subtle job and on the photos it looks even more subtle. I'm not a big fan of weatherings that look like the bot got sunk five times. I hope the washings and filters will go well together with the acrylic clear coat I'm going to apply next. Well, we'll see. Next is the weathering of the lower hull. As it is les detailed, it should be a quicker job than the upper hull.
DrSchmidt
And on we go.....the machine frame is ready.Here some pictures. Just the receiver, gaskets and bellows, and then I can check if everything is watertight.
Also additional work on the upper hull. Finished the mechanics to extend the snorkels and the chain drive of the upper rudder. The snorkels are actuated via a Firgelli linear servo which is located in an watertight compartment below the conning tower.
DrSchmidt
Postby PaulC » Fri Jul 04, 2014 9:34 am
Wow, I love it, DrSchmidt. Amazing presentation of an amazing build! That's the first time I've seen the Archer rivets on a model. They really look good.
Postby DrSchmidt » Fri Jul 04, 2014 10:05 am
Tha Archer rivets work great. But one must not forget to seal them with microsol before painting. Otherwise the transparent carrier film will start to dissolve and that doesn't look nice.
DrSchmidt
Postby PaulC » Fri Jul 04, 2014 11:35 am
Good tip. I'll keep that in mind. Looking forward to the next installment!
Postby DrSchmidt » Sat Jul 05, 2014 12:29 pm
Well, the submarine test pool has been installed :D
And the first tests of the WTC have been performed. So far everything works fine. Tomorrow I'll conduct a harder test program.....
DrSchmidt
Postby dhffr » Tue Jul 08, 2014 12:46 am
Without a doubt, the nicest tooling and build I have seen here.
AMAZING!
Darrin
dhffr
Postby DrSchmidt » Tue Jul 08, 2014 2:29 am
Thanks allot. I'm trying my best :D
DrSchmidt
Postby bwi » Fri Jul 18, 2014 11:03 am
This is top-notch work....very impressive.
Grtz,
Bart
"Samuel Smiles"
https://www.facebook.com/CleanSweepModels
bwi
Postby DrSchmidt » Sat Jul 19, 2014 7:43 am
Tnanks :D
I'm going to start to balance the boat today. That's going to be interesting......
DrSchmidt
Postby DrSchmidt » Sat Jul 19, 2014 11:43 am
O.K.: The boat is almost ready. Only some ropes are missing, but for handling reasons those will be added later. Next is the balancing of the boat. So here some photos:
The upper rudder is driven by the main rudder and thereby also drives the push rods and chain drives that used to actuate the rudder in the original:
The snorkels can be extended and retracted by a linear servo:
DrSchmidt
Postby DrSchmidt » Tue Aug 05, 2014 4:21 am
Adding buoyancy via pu foam did the Job. First time the boat floats on even keel and at the right water line.
DrSchmidt
Postby tomwittstock » Tue Aug 05, 2014 7:34 am
The older boats are incredible to look at without a doubt...............Great work..... 8)
tomwittstock
