Bronco Type XXIII build
Re: Bronco Type XXIII build
Postby roedj » Wed Jun 05, 2013 5:19 pm
Bigdave wrote:I made a bulkhead master and mold today.
This way I only have to get it right once.
If you need more than one part of the same type and molding rubber it is the only way to go. :mrgreen: BD.
BD,
Very, very nice work.
But please tell me, how did you determine the shape of the bulkhead? Trial and error? From a drawing?
Keep posting those nice pictures.
Dan
roedj
Postby Bigdave » Wed Jun 05, 2013 6:55 pm
Sort of trial and error. :roll:
I started by tracing the inside of each 1/2 hull using the rear sections.
Which when traced side to side on thin cardboard I ended up with a slightly oversized section.
I keep a stash of cereal box cardboard which is great for pattern making.
I then trimmed this so it fit the best I could get it to the inside of the hull.
Then I transferred this to a Alumilite round I keep in different sizes for projects.
(I mold them myself)
I cut out the shape using my scroll saw and sanded it to get the final fit.
So basically trial and error. :mrgreen:
I lucked out with the hull being split in four sections. :D BD.
Postby roedj » Wed Jun 05, 2013 7:39 pm
BD,
Thanks for your reply and explanation.
Looking forward to the rest of the build. Hope to see you and it at the Sub Regatta.
Dan
roedj
Postby salmon » Wed Jun 05, 2013 8:41 pm
I also like the batteries low like that, what are you going to use and running at what voltage?
Postby Bigdave » Thu Jun 06, 2013 7:03 am
You can see the battery tube in the last photo.
It has two 123 cells inside.
The 123’s are rated for 3.3V giving me 6.6V. The water proof switch turns on the tube power.
I normally have a flood hole mounted under the switch which I can access with a small hook tool. BD.
Postby MFR » Thu Jun 06, 2013 10:48 am
Dave,
Since you are making those bulkheads, i presume you are going to tackle the vertical split, it can be done, you know that.
It will be interesting to see which variation you will be designing.
Manfred.
MFR
Postby Bigdave » Thu Jun 06, 2013 5:04 pm
Posting some photos.
Will post text later.
Postby Bigdave » Thu Jun 06, 2013 5:36 pm
Text. :P :P :oops: :?
Postby Bigdave » Thu Jun 06, 2013 5:49 pm
Sorry, always the wise guy.
Seriously. :lol:
My bulkhead mold worked out great so I had to try out my driveline today.
I have a short video coming.
Everything was just sitting in the hull and the prop was to big but it works.
I also figured out how I will hold the hull half's together.
I will have some brass L brackets on the inside along the seam in two places and two flathead screws on the tail above and below the rudder.
No don't tell my friend Crazy Ivan I am using exposed external fasteners on the hull. :cry: :cry: :shock:
But if done the right way to make them inconspicuous you will not notice them.
I would rather do that than cut up a perfectly good hull to open it up.
The screw slots follow the weld lines and once painted the same color as the hull will be invisible. :mrgreen:
I made some cool stanchions that are threaded and accept the flat head screws. BD.
Postby Bigdave » Thu Jun 06, 2013 5:53 pm
Postby Bigdave » Fri Jun 07, 2013 7:26 pm
Postby Greg W » Fri Jun 07, 2013 7:53 pm
Looks good BD. she looks like she'll be ready for trials soon. :D
Greg W
Postby redboat219 » Sat Jun 08, 2013 11:15 am
Are you only going to use the stern planes?
redboat219
Postby Bigdave » Sat Jun 08, 2013 4:53 pm
Yes, I think so.
At least at first.
I do not like using bow planes. :roll:
On the subs I have that they do actually work I never use them.
Give me a good stern plane any day. :mrgreen:
Postby redboat219 » Mon Jun 10, 2013 6:45 am
No onboard automatic leveling system i presume?
redboat219
