Engel Tmax troubles any one who has one
Postby brutis11 » Wed Feb 15, 2012 7:34 pm
I have hooked up my t max and motors to the cilinders and am having a problem, using K5 to test hooks to my receiver and it is a 3 position switch, using a regular servo to test in the I position servo is on 1 side, switching to 2 position it it goes to middle and 3 goes to other side.Then I removed the servo from the test When I put power to the tmax I here a relay pull in and the piston on both sides pull the piston all the way in and then it pushes out and stops. I tried moving the 3 position switch and nothing happens. I have the poitioners hooked to the tmax but do not have the them hooked to the receiver yet, also I do not have the pleasure switch hooked up yet. I followed the wiring diagram to the tea and triple checked my work what is going wrong? Could it be that I do not have K6 &K7 hooked to the receiver. any Ideas. I am stopping right now to I here from you I don’t want to break anything, but funny thing is when I turn power it cycles every time, but wont work after that.
Any Ideas?
Thank
you
Jim Davis
brutis11
Re: Engel Tmax troubles any one who has one
Postby Sub culture » Thu Feb 16, 2012 10:40 am
Pleasure switch?
What's that then, sounds interesting- you must have the deluxe model. :P
I dare say 'Wheelerdealer' or 'Bob the builder' can give you some tips on this on this one.
Postby brutis11 » Thu Feb 16, 2012 1:25 pm
Good day
after rechecking my wiring all is good and I was still having error. I was on channel 8 which was a 3 way switch. on my radio I have another 3 way switch on channel 5. I changed the programing to make channel 5 a switch. Now everything is working right. I am getting 90% stop and move switch now get 100% so it must have been my radio
so life is good, now I have to drill lots of holes
JIm
brutis11
Postby brutis11 » Thu Feb 16, 2012 1:29 pm
Sometimes, a model can be overengineered :roll:
brutis11
Postby StuartL » Mon Feb 20, 2012 3:50 pm
brutis11 wrote:Sometimes, a model can be overengineered :roll:
Sometimes a model isn't overengineered. That's slightly rarer :)
StuartL
Postby brutis11 » Thu Feb 23, 2012 8:30 pm
The mystry problem started up again so in my frustation I removed all wireing from boat and tested all switches and as running new wire I Ohmed it out and to my surprise everythig works correctly. Now what caused the problem I went back through all of the wire I removed and found a bad servo harness and and a bad piece of #14 guage wire I had used for the main bus, so I was looking at a couple of bad pieces of wire and I could have also reversed wired something in the process. So I am happy now and am enjoying the build of the model and I can apprecate the detail that was put into the hull. Thanks all for your comments and help on this issue, but it is over now.
Thanks again
Jim :)
brutis11
