Upgrading a Thor Design's 637
Re: Upgrading a Thor Design's 637
Postby Tommydeen » Sat Aug 20, 2011 2:07 am
no worries Tim..I know all about duty.. its all good :wink:
Tommydeen
Postby SubICman » Sat Aug 20, 2011 9:35 am
Tom,
Here you go, I took a crap ton of pictures of the towed array tube and fairing. Hope it helps, Getting ready for our Subron 4 meeting today.
One word about the towed array fairing casting. The alumilte continued to cure and shrink, at the beginning of this year, I had to re-attach the fairing and pin it into place, hence some of the primer spots on the casting. My plan is to repaint topside this winter
SC #3116
SubICman
Postby SubICman » Sat Aug 20, 2011 10:06 am
Opps,
Forgot the ones with the ruler in the pic. I only have a steel one so thery are not the best.
SC #3116
SubICman
Postby SubICman » Sat Aug 20, 2011 10:22 am
Continueing with the mast construction. I cut pieces out and placed them up against the scale drawings to get the lengths and curves set right. I took a piece of brass tubing (can't seem to find the size I used in my notes) and squashed it into an oval with a vise to form the antenna portion. I also pulled my scope barrel out of the resin mast. For the BLA-4 i turned to my trusty acient Craftsman metal lathe and turned a new antenna for that. I soldered everything together very carefully, when working with stuff this small, a micro torch is a MUST!
SC #3116
SubICman
Postby Thor » Sat Aug 20, 2011 3:45 pm
Tim,
Yes! When you get those drawings done send them over and I will get to work doing what I can. I should have everything set up in the new shop by late spring and my health should be back to the point that I can operate the machinery. I really miss that old Sturgeon of mine. I wish I could remember who I sold my old boat to. I would buy it back. It was the one I had at the 1994 & 1995 Regatta. What a stupid move to sell that boat!!!
Postby Tommydeen » Sun Aug 21, 2011 3:46 am
Wow thanks alot Tim the pics help!!!!!
Tommydeen
Postby Rogue Sub » Thu Aug 25, 2011 10:50 pm
Tim- BUTCHER!!
Thor- I thought I was your favorite Nuke?
Postby Thor » Fri Aug 26, 2011 4:40 pm
:roll:
oh, boy......
Postby wlambing » Fri Aug 26, 2011 4:55 pm
Kevin,
You are, dork! Tim is a non-nuke twigget!!!!! Formerly a two-wire electrician. Sheeeshh!! How quickly they forget!!
B^)
MMCS(SS) USN (Ret.)
World's greatest living Submarine Auxiliaryman
and friend to small furry creatures
wlambing
Postby Rogue Sub » Fri Aug 26, 2011 8:29 pm
Bill are you a member of the furies?
Postby Rogue Sub » Fri Aug 26, 2011 8:37 pm
Just so there are no misunderstandings....
Postby wlambing » Sat Aug 27, 2011 9:39 am
Kevin,
No. They're not small, nor furry enough!
B^)
wlambing
Postby Rogue Sub » Sat Aug 27, 2011 10:05 am
I am not convinced
Postby JWLaRue » Sat Aug 27, 2011 2:12 pm
....nor pink enough? :)
Postby SubICman » Wed Aug 31, 2011 7:43 pm
jeez, go out to sea for a week and you guys hijack my thread for FURRIES?!?!?!?!
SC #3116
SubICman
