1/72nd scale alfa class ssn
Re: 1/72nd scale alfa class ssn
Postby the dark knight » Wed Feb 16, 2011 1:38 pm
sooo... ive been thinking alot and will be building a second plug to pull my mold off of. this one has too many issues with it to make a mold from and i am impatient and want it done :lol: , so i will be continuing it as a one off hull. soo... here is where it stands now. i marked and drilled the free flood holes, roughed in the reactor intake scoops, and scribed the lines on the deck. after looking at photos, im missing 6 free flood holes not on the plans... hmmm... and i need to drill them out, and drill out the vents in the conning tower. the diveplanes for the stern have been roughed in as well.
Jon Jones
the dark knight
Postby Thor » Wed Feb 16, 2011 2:22 pm
For your first whirl at this you have done a superb job!
Postby the dark knight » Wed Feb 16, 2011 2:38 pm
thanks Matt. that means alot coming from you! ive learned alot, and will be making my IXD plug the master for the mold, rather than a one off. i learned scribing all those little hatches is a giant pain in the kester. i have a much better understanding as to the work that goes into making the masters for these submarines. its alot of work! my hat is off to you guys that make these for the rest of us. :wink:
edit, thanks Matt!
Jon Jones
the dark knight
Postby the dark knight » Thu Feb 17, 2011 3:16 pm
last nights progress-
i finally got this hull apart after 4 hours of cursing, scratching my head, prying, cursing some more. the cut went very nicely and the little hobby saw i used worked wonders, it removed so little material i think i dont have any reconstruction to do. i finally broke down and poured acetone down the stern in the hole where the prop shaft will go. that made life a little easier. here is where the alfa sits now.
and apart
with the advice of Matt Thor, i decided to do a Z cut. it was alot of work, but it does look nice. tonight i plan on starting to make the free flood holes square.
Jon Jones
the dark knight
Postby the dark knight » Thu Feb 17, 2011 11:43 pm
i started making the free flood holes square. i learned something here! before i was trying to do it before i removed the foam. what a pain! removed foam and its running like clock work!
bondo is drying on the hull now. i made a few boo-boos while splitting the hull. i got a little impaitent and chipped the hull in a few spots at the seperation line. once its dry, i will resume filing the free flood holes. thats it for now folks!
Jon Jones
the dark knight
Postby the dark knight » Sat Feb 19, 2011 8:04 pm
well, not much done today.... i scribed the torpeado tube doors on today. sadly, thats all i was able to get done today. more tonight i hope!
Jon Jones
the dark knight
Postby GreyAkula52 » Sun Feb 20, 2011 12:05 am
Very Nicely Executed.......... :wink:
Captain Andre
Andre S. Burgess, P.E.
GreyAkula52
Postby the dark knight » Sun Feb 20, 2011 11:17 pm
thanks Andre!
Jon Jones
the dark knight
Postby the dark knight » Mon Feb 21, 2011 12:13 am
today i started putting the hull back together. or should i say started to figure out how to put the hull together when its in the water. i glued in 4 bulkheads, my logic here is that i will mount alignment pins in 2 of them, and the corresponding bulkheads will have holes the pins will drop into. i will still need a few alignment tabs to keep the hull in alignment, but i think this will help as well. time will tell. any way, tomorrow i will glue in the pins, and drill the holes. enjoy!
forward bulkheads-
rear bulkheads-
Jon Jones
the dark knight
Postby the dark knight » Wed Feb 23, 2011 12:33 pm
tabs have been installed in the upper hull. will do the lowers soon!
Jon Jones
the dark knight
Postby the dark knight » Tue Mar 01, 2011 12:03 am
i am happy to announce more progress has been made on alfa. i added the indexing tabs to the lower hull today and re-designed my alignment tab for the rear. yep! i deleted the bulkhead and added a piece of plastic in its place. in theory i think it should work.
and last but not least, the lower hull tabs!
Jon Jones
the dark knight
Postby redboat219 » Wed Mar 02, 2011 12:20 am
Dark knight,
Great build you got going here. I'll be watching this thread very closely. Might try to make my own Alfa someday although in a much smaller scale like 1/96 (to cut down on fiberglass and resin cost). BTW, can you show how you were able to scribe the torpedo doors on the curved bow.
More power.
redboat219
Postby the dark knight » Wed Mar 02, 2011 11:30 am
redboat219 wrote:Dark knight,
More power.
Thanks redboat! to be honest with you, i took a good long look at my plans and these two photographs
and i drew them out in pencil multiple times until i got the shape to match the photographs. then i marked them in sharpie and scribed them. sorry, i didnt take photos of that process.... as for costs so far, i might have $70-80 dollars in this between the bondo, fiberglass and foam plug. i thought of going 1/96th, but i felt like the hull would be too small inside for what i wanted to do with this sub. even in 1/72nd scale, it seems cramped compared to that monster IXD2 im building.
Jon Jones
the dark knight
Postby redboat219 » Wed Mar 02, 2011 10:26 pm
That's one crusty alfa :-D
Anyway, did you you use a template to help in scribing or did you do it freehand?
redboat219
Postby the dark knight » Thu Mar 03, 2011 11:08 am
she is a little crusty isnt she? :lol: i free handed it. if you look close i didnt get them to perfectly match one another. looking back, i wish i had made a template. i still could i suppose, for V2. ill let you know how it turns out and ill post it up if it works!
Jon Jones
the dark knight
