YMCA in one hour.
YMCA in one hour.
Postby Bigdave » Sun Mar 30, 2008 6:06 pm
Be there or be square!! :lol: :wink: BD.
Postby Crazy Ivan » Mon Mar 31, 2008 12:32 am
Well it was good to finally get back to our old winter home at the Y. Attendance was 100%, with Don and Patty Osler, Big Dave Welch, Paul Strassner, Don May, Larry Kuntz, Scott Russell, Mike Caswell along with two friends, and yours truly all present and accounted for. It was a chance to get caught up on what everyone else has been up to all winter, shoot the bull a bit and, of course run subs! Well some of us got to run anyway. It seems we had a visit from the RF gremlins a short time into the run.
I was in the process of trimming out my newly reconfigured Revell Gato when suddenly all my servos went berserk. About this time, Mike's Seawolf went out of control to the bottom and had to be retrieved with a net. Big Dave's Seawolf also refused to answer its command signals. The common factor? All three of us were using Polk Seeker II receivers. These units are synthesized, and must acquire the proper signal to initialize. They just could not get a lock. I tried to set my Tracker III transmitter to another channel, but everything kept coming back as "BUSY". A quick check of the local electromagnetic atmosphere with Don Osler's frequency scanner showed at least half of all the available channels lit up. Something drastic inside the building had suddenly changed, and we never did determine what it was. The three of us were drydocked for the night, so we just watched the other subs run and socialized a bit. I took some pictures. Here are some of them:
Right click on "View Image" for larger view
Paul Strassner and his kayak
Larry running his Akula and Don Osler
Big Dave and Don May
Mike Caswell and friends
Mike's boats
Scott Russell and his little Yellow Sub
Happy Faces!
Crazy Ivan
Postby Larry Kuntz » Mon Mar 31, 2008 8:22 am
Great photos CI. At least you got time to snap some photos since you couldn't run. Nice to get back together again.
Now to figure out the Seeker II problem. :?: :?: :?: :?:
Larry Kuntz
SubRon8
Larry Kuntz
Postby SeaHorse » Mon Mar 31, 2008 12:39 pm
CI, thanks for the write up and for posting the pictures!
Haven't had a chance to sift through the videos from last night, but hopefully I will have a few to post later tonight.
It was great to finally get out and stretch my R/C legs. Nothing like sniffing pool chemicals in that 90 degree indoor temperature. :)
Paul Strassner
SC 2813
SeaHorse
Postby Bigdave » Mon Mar 31, 2008 1:37 pm
I would not have missed it. :D
I even got to see Paul do his banana dance. Dam video camera was off at the time. :roll:
I hope I got some good video of the subs. 8)
I will check tonight. BD.
Postby Crazy Ivan » Mon Mar 31, 2008 4:32 pm
Needless to say, my radio worked fine as soon as I got home. :?
Crazy Ivan
Postby kazzer » Mon Mar 31, 2008 10:11 pm
Well, at least I got another ten minutes 'stick time'! I must be up to all of three hours total now! :roll:
When you don't know what you are doing, it comes hard to see your boat playing up. Finding out that it wasn't my fault, didn't help much! :oops:
I did get to see my Snort working on the Valiant.
My pool is melting around the edges, so with luck, I could be finishing off trimming her out in the next week or so.
It was good to see the gang again. Did I see a Holland there?
kazzer
Postby Larry Kuntz » Tue Apr 01, 2008 8:10 am
As an after thought, we should have switched off all of our regular transmitters and see if you guys could get a lock on the Seekers first. Always hard to simulate problems once we leave the Y. We may have been flooding the room with multiple interference signals. RF wise, that is a strange structure.
Larry Kuntz
SubRon8
Larry Kuntz
Postby Bigdave » Tue Apr 01, 2008 3:36 pm
I was thinking that too. We need to do some testing. I was running for 1/2 hour fine until the Trackers turned on. :cry: :cry: Then I lost lock on the R/X. :roll: I am using a Seeker-6 R/X in the Seawolf but my Multiplex T/X. Strange. :? :? BD.
Postby JWLaRue » Tue Apr 01, 2008 7:25 pm
We had some perhaps similar problems during some of the SubComEast runs a couple of years back. The Tracker either wouldn't lock to a frequency when turned on.
The work-around was to greatly increase the distance between the Tracker (receiver and transmitter) and the *other* subs running while trying to get a lock. The thinking is/was that all the metal roof beams were causing some sort of reflectance problem.
It would be interesting to see if you can replicate the problem and then see if putting distance between the transmitters helps any.
More pictures from the run
Postby donO » Mon Apr 07, 2008 9:18 pm
Don Osler
donO
Postby Larry Kuntz » Tue Apr 08, 2008 7:57 am
Thanks Don. These are good photos. I have a new mount for the camera to try Sunday. Hope to get some good video. :D
Larry Kuntz
SubRon8
Larry Kuntz
Return to SubRon8
