Navy removes C.O. for Bangor, WA nuc. weapons facility
Postby U-5075 » Fri Oct 09, 2009 7:22 am
A bit late with this info. There was not very much released about this.
Also no scuttlebutt afterwards.
http://blog.taragana.com/n/navy-removes ... ty-146709/
Navy removes commanding officer who oversaw Bangor, Wash., nuclear weapons facility
Bureau News
August 22nd, 2009
BANGOR, Wash. — The Navy dismissed the commanding officer of a Washington state-based nuclear weapons facility Friday, citing a loss of confidence in his ability to lead, the Pentagon said.
Capt. Timothy J. Block, who headed the Navy’s Bangor operation arming Trident submarines with nuclear warheads, was relieved of duty on by Rear Adm. Stephen E. Johnson, the Navy’s director of strategic systems programs, according to the Kitsap Sun.
A Navy spokesman told The Associated Press that no single incident led to Block’s removal. The spokesman would only comment anonymously because he felt he should not pre-empt his supervisor.
Pentagon spokesman Cmdr. J.A. “Cappy” Surette told the newspaper that public safety was not jeopardized and that no “specific issue” was involved.
Washington state’s Naval Base Kitsap-Bangor is home to nuclear submarines, ships and laboratories. The facility also assembles and stores nuclear weapons before outfitting the subs.
Block was about a year into a three-year stint. Surette says the captain has been reassigned but his next station has not been determined.
Navy Capt. Kevin Zumbar, deputy director of strategic systems programs based in the Washington, D.C., area, will take over command until a replacement is found.
Block is the second facility commander in recent years to be relieved of duty for “a loss of confidence.” Capt. Keith Lyles was dismissed after failing a nuclear weapons inspection om 2003.
Information from: Kitsap Sun, www.kitsapsun.com/
Also one other reference.
http://blog.thenewstribune.com/military ... ef-canned/
U-5075
Postby U-5075 » Fri Oct 09, 2009 9:02 am
There was, indeed, a fairly good amount of discussion. I had missed it.
http://bubbleheads.blogspot.com/2009/08 ... l#comments
U-5075
Postby U-5075 » Fri Oct 09, 2009 7:19 pm
Please note the reason for another commander being dismissed back in 2003 was rather interesting. The dismissal followed the failing of a weapons inspection. And the inspection followed an incident highlighted below.
http://www.kitsapsun.com/news/2009/aug/ ... -commandi/
Navy Fires Top Officer at Bangor Nuclear Weapons Facility
By Josh Farley (Contact)
Friday, August 21, 2009
BANGOR — Capt. Timothy J. Block, the commanding officer of Bangor’s nuclear weapons facility, has been relieved of duty, according to a Navy spokesman.
Rear Adm. Stephen E. Johnson, the Navy’s director of strategic systems programs, removed Block on Friday because of “a loss of confidence in his ability to continue to lead,” said Cmdr. J.A. “Cappy” Surette, a spokesman at the Pentagon.
“An officer in command has a unique position of trust and responsibility, and has a key role in shaping morale, good order and discipline within the command,” Surette said. “Because of this unique position, his immediate superiors must have full confidence in the officer’s judgment and ability to command.”
Surette said there was no “specific issue or incident” that led to Block’s removal and that public safety was not jeopardized at the facility, which assembles, stores and places nuclear weapons on submarines.
He is the second SWFPac commander in six years to be relieved of duty for “a loss of confidence.” Capt. Keith Lyles — along with his executive officer, weapons officer and command master chief — was dismissed after failing a nuclear weapons inspection.
That inspection came six weeks after a ladder was inadvertently left inside a missile tube on the Trident submarine USS Georgia. As a nuclear missile was being lifted into the tube, the missile’s nose cone was punctured by the ladder and the lifting operation only stopped when the ladder was inches from the nuclear warhead.
The Nov. 7, 2003 incident, which occurred on the Bangor waterfront, was described by a local congressman who had been briefed on it as “serious” but not life-threatening.
Block was about a year into his three-year tour. He has been reassigned and his next duty station has not been determined, Surette said.
Navy Capt. Kevin Zumbar, deputy director of strategic systems programs based in the Washington, D.C., area, will assume command until a permanent replacement is found.
The Strategic Weapons Facility Pacific is home to about one-fourth of the nation’s nuclear weapons, according to a 2006 report by the The Bulletin of the Atomic Scientists, a nuclear weapons watchdog group.
U-5075
Return to Subs in the News
