New Russian Boomers stumble
Postby Novagator » Thu Aug 03, 2006 8:32 am
New Russian Boomers Stumble
August 1, 2006: Russia has run into yet more technical problems with its new "Borei Class" of ballistic missile nuclear subs (SSBN, or "boomers"). The launching of the first ship in the class, the Yuri Dolgoruky, has been put off from late this year, to early next year. Construction of the Yuri Dolgoruky began ten years ago, but money shortages, and technical problems, have slowed progress.
The second ship in the class, the Alexander Nevsky, is also nearing completions. Construction on the third, the Vladimir Monomakh, began earlier this year. Russia wants to have about a dozen of these boats, to replace the Delta IV class SSBNs that are currently in service. The Delta IVs are getting old, and have only about a decade of useful service left.
The Borei's are closer in design to the Delta IVs, than to the more recent, and much larger, Typhoon boats. The Boreis are 558 feet long and 44 feet wide. Surface displacement is 15,000 tons, and twelve Bulava SLBMs (Sea Launched Ballistic Missile) will be carried. Work on the Yuri Dolgoruky was delayed for several years because the first missile being designed for it did not work out. A successful land based missile, the Topol-M, was quickly modified for submarine use. The Bulava was a larger missile, cutting the Borei's capacity from twenty to twelve missiles. The boat also has four torpedo tubes, and twelve torpedoes or torpedo tube launched missiles.
The Boreis have a crew of 107, with half of them being officers (a common Russian practice when it comes to high tech ships like nuclear subs). Each of these boats will cost at least two billion dollars. This high cost, by Russian standards, is partly because many factories that supplied parts for Russian subs were in parts of the Soviet Union that are not now within the borders of present day Russia. So new factories had to be built. All components of the Boreis, and their missiles, will be built in Russia. A dozen of these boats probably won't be completed for at least a decade.
John Cottingham
Sub Committee Member #2721
Novagator
Return to Subs in the News
