How did I get this??
Please use this forum to ask those "how to" questions on using all the interesting features available with our new forums.
Postby Crazy Ivan » Tue Apr 15, 2008 9:13 pm
I always have plenty of problems doing a "View posts since last visit", usually having to open and close some random post first before it allows me to do so. But today my work-around is failing and I keep getting this message I have never seen before:
General Error
Could not insert search results
DEBUG MODE
SQL Error : 1062 Duplicate entry '1475336259' for key 1
INSERT INTO phpbb_search_results (search_id, session_id, search_time, search_array) VALUES(1475336259, 'f2839ebd1639f5edda99d12ae37b6bcf', 1208308170, 'a:7:{s:14:"search_results";s:64:"6891, 7305, 7338, 7348, 7351, 7360, 7362, 7363, 7364, 7365, 7366";s:17:"total_match_count";i:11;s:12:"split_search";N;s:7:"sort_by";i:0;s:8:"sort_dir";s:4:"DESC";s:12:"show_results";s:6:"topics";s:12:"return_chars";i:200;}')
Line : 706
File : search.php5
Crazy Ivan
Postby JWLaRue » Tue Apr 15, 2008 9:57 pm
George,
Odd error message.......the view posts since last visit works fine for me using either IE or Firefox. What browser are you using? Once the error occurs, is it repeatable?
Postby bcliffe » Wed Apr 16, 2008 8:25 am
Jeff,
This would not be a browser problem. There is a data problem in the mySQL database the PHP web pages use.
Each user has a majic number associated with them, my guess is George's is '1475336259'
The code has successfully retrieved the pages that George wants, but when it goes to put it the table that the browser will pull from, it will fail saying that George's key is already in the table (so being used)
The solution is to purge data found in table phpbb_search_results with search_id 1475336259
If you wanted to see this issue, you would need to use George's userId.
Cheers
BC
bcliffe
Postby Crazy Ivan » Wed Apr 16, 2008 9:04 pm
Jeff,
Last night it happened every time I tried it. It is not happening today. My normal workaround did fine just now. Gremlins. FYI, I use Firefox 2.0.0.13
Crazy Ivan
Postby JWLaRue » Wed Apr 16, 2008 10:00 pm
George,
What is the work around?
Postby Crazy Ivan » Thu Apr 17, 2008 8:50 pm
I was referring to the workaround I have to do when I get the message "You cannot make another search so soon after your last; please try again in a short while", which happens about half the time I log in. As I mentioned above, when I see this message I have to open then close a post, any post, then I can search. The error which prompted this thread, however, is something I had never seen before. There was no getting around it that night and it hasn't happened since (knock on wood).
Crazy Ivan
Postby JWLaRue » Thu Apr 17, 2008 9:10 pm
George,
We've asked our web hosting guy to take a look into the database that holds the forum information to see what's up.
Postby hakkikt » Fri Apr 18, 2008 12:02 am
Probably not really helpful, but the same thing that happens to George ("You cannot make another search so soon after your last; please try again in a short while.") happens to me regularly too.
- mobilis in mobili -
SC#1604
hakkikt
Postby PaulC » Fri Apr 18, 2008 8:05 am
I've experienced that error before ("You cannot make another search so soon after your last; please try again in a short while") but on other forums, never here.
Postby Crazy Ivan » Fri Apr 18, 2008 12:16 pm
What really puzzles me is why should anybody even care how often someone searches? Seems like an odd bit of code to me.
Crazy Ivan
Postby JWLaRue » Fri Apr 18, 2008 12:54 pm
Oh....that's to limit the impact of web crawlers, so they don't bog down the system.
Postby Crazy Ivan » Fri Apr 18, 2008 9:07 pm
Ah, I see. Well, I haven't crawled on too many webs lately myself. :wink: :wink:
Crazy Ivan
Postby Crazy Ivan » Thu Apr 24, 2008 10:45 pm
Hey, that wait-10-seconds-and-try-again trick really works, Jeff! Much better than what I was doing. Maybe my routine only worked because it took 10 (or more) seconds to do. :? Now this is a workaround I can live with! :D
p.s. No sign of that database error since that one night. :P :P
THX for looking into it.
Crazy Ivan
Postby Rogue Sub » Mon Jul 07, 2008 11:31 am
I am now having this problem more and more. It is happening regardless hos how long I wait aswel. 1 min 20 min 30sec.... Its like russian rulete for me and I am going bonkers. We need to fix it. Is our site that overloaded???
Postby JWLaRue » Mon Jul 07, 2008 1:03 pm
We're going to 'side step' the problem through the process of upgrading to a new version of the phpBB software...... :)
Return to Forum Tips & Tricks
