Q -- How to find or build WTC 90mm x 900mm ?
Postby menatarms » Tue Feb 02, 2010 11:34 pm
Hello, does anyone know whether there is a ready supplier of WTC dimension: 9cm diameter x 36 inches approx (92cm length),
or supplier of raw components for custom DIY build of ?? Any information would be greatly appreciated~! ;)
menatarms
Re: Q -- How to find or build WTC 90mm x 900mm ?
Postby Sub culture » Wed Feb 03, 2010 8:14 am
Sub Tech do a 90mm module-
http://www.subtech.uk.com/acatalog/All_ ... Subs_.html
Small World models, Caswell/D&E produce 3.5" diameter WTC's, which is very close to the size you need-
http://www.smallworldmodels.com/wtc/wtc.html
http://www.caswellplating.com/models/sub-drivers.html
Also you have Ark model in China who do 100mm diameter WTC's, which may be too big for your requirements?
http://www.arkmodel.com/Frameset-1e.htm
Last but not least, OTW here in the UK also do 100mm modules
http://www.otwdesigns.com/DiveSystems/divesystems.htm
Postby menatarms » Sat Feb 13, 2010 2:09 am
Thanks for that info. It's very helpful. ;)
menatarms
